The URL `docs-4.2.1.10/installation/6-kubernetes-installation/11-common-scenario` does not exist. This page may have been moved, renamed, or deleted.
- [Minor upgrade](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade/minor-upgrade.md)
- [Major upgrade](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade/major-upgrade.md)
- [Amazon EKS](https://docs.openiam.com/installation/kubernetes/amazon-eks.md)
- [After a major upgrade](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade/after-a-major-upgrade.md)
