The URL `docs-4.2.1.10/installation/6-kubernetes-installation/2-deployment-with-terraform` does not exist. This page may have been moved, renamed, or deleted.
- [Deploy with Helm](https://docs.openiam.com/installation/kubernetes/deploy-with-helm.md)
- [Minor upgrade](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade/minor-upgrade.md)
- [Upgrading OpenIAM](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade.md)
- [Major upgrade](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade/major-upgrade.md)
- [Prepare the cluster](https://docs.openiam.com/installation/kubernetes/prepare-the-cluster.md)
GET https://docs.openiam.com/installation/kubernetes/deploy-with-helm.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/kubernetes/deploy-with-helm.md`).
