The URL `docs-4.2.1.10/admin/12-administration/1-sysconfig/3-UI` does not exist. This page may have been moved, renamed, or deleted.
- [Administration Guide](https://docs.openiam.com/administration-guide/admin.md)
- [Manage non-human identities](https://docs.openiam.com/administration-guide/nhi.md)
- [Add Duo as a second factor](https://docs.openiam.com/administration-guide/security/duo.md)
- [Caddie — Access Review Assistant](https://docs.openiam.com/administration-guide/caddie.md)
- [Secure sign-in and credentials](https://docs.openiam.com/administration-guide/security.md)
GET https://docs.openiam.com/administration-guide/admin.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/administration-guide/admin.md`).
