The URL `docs-4.2.1.10/installation/1-rpm-installation/1-singlenode` does not exist. This page may have been moved, renamed, or deleted.
- [Single node](https://docs.openiam.com/installation/rpm/rpm-single-node.md)
- [Minor upgrade](https://docs.openiam.com/installation/rpm/rpm-upgrade/minor-upgrade.md)
- [Install](https://docs.openiam.com/installation/rpm/rpm-ha/install.md)
- [Install](https://docs.openiam.com/installation/rpm/rpm-single-node/install.md)
GET https://docs.openiam.com/installation/rpm/rpm-single-node.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/rpm/rpm-single-node.md`).
