Authentication tab
The Authentication tab contains configuration options for user authentication.
Authentication tab
FieldDescription
API call base domainThe base domain or URL used for making API calls.
Send email with approval link for new deviceThis checkbox indicates whether the system sends an email containing an approval link when a new device is added, and the user needs to confirm or approve the addition of the device.
Inform user about new deviceThis is a setting to notify the user whenever a new device is added to their account.
Send email with approval link for new IPSimilar to the device scenario, this checkbox suggests sending an email with an approval link when a new IP address is associated with the user's account.
Inform user about new IPThis is a setting to inform the user when a new IP address is detected for their account.
Send email with approval link for new locationThis checkbox indicates sending an approval link via email when a user's account is accessed from a new location.
Inform user about new locationThis is a setting to notify the user whenever their account is accessed from a new location.
Use certificate for authenticationThis checkbox suggests the use of a certificate for authentication.
RP IconThis refers to an icon associated with an RP, which is a component that relies on an identity provider for authentication.
RP NameThis is likely the name associated with a relying party in the authentication process.
Use Web AuthenticationThis checkbox indicates whether the system supports or requires web-based authentication methods.
Include OAuth2 authorization URL in consent scopeThis checkbox is related to including the OAuth2 authorization URL as part of the consent scope during the authentication process.
Time threshold for SAML ResponsesA setting defining a time threshold for processing SAML (Security Assertion Markup Language) responses.
Send Activation Link to new usersThis checkbox suggests sending an activation link to new users for account activation.
Default Base DomainThis is the default domain used for various purposes within the system.
