The URL `docs-4.2.1.10/installation/7-OpenShift-installation/2-connect-to-cluster` does not exist. This page may have been moved, renamed, or deleted.
- [Connector strategy: how each system is reached](https://docs.openiam.com/solution-architecture/integration/connector-strategy.md)
- [Prepare the cluster](https://docs.openiam.com/installation/kubernetes/prepare-the-cluster.md)
- [The clustered tiers](https://docs.openiam.com/installation/rpm/rpm-ha/form-the-clusters.md)
- [Connector placement](https://docs.openiam.com/solution-architecture/integration/connector-placement.md)
- [Connect OpenIAM to Active Directory](https://docs.openiam.com/getting-started-guide/lifecycle/connect-to-ad.md)
GET https://docs.openiam.com/solution-architecture/integration/connector-strategy.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/solution-architecture/integration/connector-strategy.md`).
