The URL `docs-4.2.1.10/installation/1-rpm-installation/5-ports` does not exist. This page may have been moved, renamed, or deleted.
- [Ports](https://docs.openiam.com/installation/rpm/rpm-single-node/ports.md)
- [Ports](https://docs.openiam.com/installation/rpm/rpm-ha/ports.md)
- [Report builder](https://docs.openiam.com/administration-guide/reports.md)
- [Prepare the hosts](https://docs.openiam.com/installation/rpm/rpm-ha/prepare-the-hosts.md)
GET https://docs.openiam.com/installation/rpm/rpm-single-node/ports.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/rpm/rpm-single-node/ports.md`).
