The URL `docs-4.2.1.10/installation/1-rpm-installation/6-upgrading/1-databasemigration` does not exist. This page may have been moved, renamed, or deleted.
- [Install on a separate partition](https://docs.openiam.com/installation/rpm/rpm-single-node/separate-partition.md)
- [Integration patterns for external systems](https://docs.openiam.com/administration-guide/operations/enterprise-integrations.md)
- [Integration: reaching the estate](https://docs.openiam.com/solution-architecture/integration.md)
- [Major upgrade](https://docs.openiam.com/installation/rpm/rpm-upgrade/major-upgrade.md)
