The URL `docs-4.2.1.10/installation/1-rpm-installation/6-upgrading/4-migrating-index-data` does not exist. This page may have been moved, renamed, or deleted.
- [Minor upgrade](https://docs.openiam.com/installation/rpm/rpm-upgrade/minor-upgrade.md)
- [Major upgrade](https://docs.openiam.com/installation/rpm/rpm-upgrade/major-upgrade.md)
- [First sign-in](https://docs.openiam.com/installation/rpm/rpm-single-node/first-sign-in.md)
- [Federate a Microsoft Entra domain](https://docs.openiam.com/administration-guide/federation/federate-a-microsoft-entra-domain.md)
GET https://docs.openiam.com/installation/rpm/rpm-upgrade/minor-upgrade.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/rpm/rpm-upgrade/minor-upgrade.md`).
