The URL `docs-4.2.1.10/admin/10-consent-management` does not exist. This page may have been moved, renamed, or deleted.
- [Terminate a user's sessions](https://docs.openiam.com/administration-guide/security/session-management.md)
- [Group management](https://docs.openiam.com/end-user-guide-for-selfservice/for-managers/group-management.md)
- [Connector placement](https://docs.openiam.com/solution-architecture/integration/connector-placement.md)
- [One person, many accounts](https://docs.openiam.com/solution-architecture/identity/one-person-many-accounts.md)
- [Environments and tenancy](https://docs.openiam.com/solution-architecture/deployment/environments-and-tenancy.md)
GET https://docs.openiam.com/administration-guide/security/session-management.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/administration-guide/security/session-management.md`).
