The URL `docs-4.2.1.10/connectorconfig/salesforce` does not exist. This page may have been moved, renamed, or deleted.
- [Salesforce.com connector](https://docs.openiam.com/connector-configuration/salesforce.md)
- [The connector synchronization source](https://docs.openiam.com/troubleshooting/connectors/sync-vs-async-source.md)
- [Connector configuration](https://docs.openiam.com/connector-configuration/connectorconfig.md)
- [SAP S/4HANA reference](https://docs.openiam.com/connector-configuration/sap/sap-reference.md)
- [SAP Fiori connector](https://docs.openiam.com/connector-configuration/sap-fiori.md)
GET https://docs.openiam.com/connector-configuration/salesforce.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/connector-configuration/salesforce.md`).
