The URL `docs-4.2.1.10/installation/7-OpenShift-installation/1-create-cluster` does not exist. This page may have been moved, renamed, or deleted.
- [The clustered tiers](https://docs.openiam.com/installation/rpm/rpm-ha/form-the-clusters.md)
- [Create a user](https://docs.openiam.com/administration-guide/identities/create-a-user.md)
- [Prepare the cluster](https://docs.openiam.com/installation/kubernetes/prepare-the-cluster.md)
- [Impersonate a user](https://docs.openiam.com/administration-guide/identities/impersonate-a-user.md)
GET https://docs.openiam.com/installation/rpm/rpm-ha/form-the-clusters.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/rpm/rpm-ha/form-the-clusters.md`).
