The URL `docs-4.2.1.10/installation/6-kubernetes-installation/6-k8platforms/1-gce` does not exist. This page may have been moved, renamed, or deleted.
- [Upgrading OpenIAM](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade.md)
- [Minor upgrade](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade/minor-upgrade.md)
- [Major upgrade](https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade/major-upgrade.md)
- [Prepare the cluster](https://docs.openiam.com/installation/kubernetes/prepare-the-cluster.md)
- [Back up and restore](https://docs.openiam.com/installation/kubernetes/back-up-and-restore.md)
GET https://docs.openiam.com/installation/kubernetes/kubernetes-upgrade.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/kubernetes/kubernetes-upgrade.md`).
