The URL `docs-4.2.1.10/installation/1-rpm-installation/1-singlenode/3-nonroot-partition` does not exist. This page may have been moved, renamed, or deleted.
- [Install on a separate partition](https://docs.openiam.com/installation/rpm/rpm-single-node/separate-partition.md)
- [First sign-in](https://docs.openiam.com/installation/rpm/rpm-single-node/first-sign-in.md)
- [Use a remote database](https://docs.openiam.com/installation/rpm/rpm-single-node/use-a-remote-database.md)
- [Enable HTTPS](https://docs.openiam.com/installation/rpm/rpm-single-node/enable-https.md)
GET https://docs.openiam.com/installation/rpm/rpm-single-node/separate-partition.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/rpm/rpm-single-node/separate-partition.md`).
