RabbitMQ TLS directory
This directory should contain required SSL-specific files for running the reverse proxy in https mode.
rabbitmq.crt- server certificate content.rabbitmq.key- server private key content.rabbitmq.ca.crt- certificate Authority (CA) bundle content.
These files must go into the root level directory .rabbitmq and openiam-configmap/.rabbitmq
Also, the following variables must be set.
In Terraform
rabbitmq.tls.enabled=true
In Helm
--set openiam.rabbitmq.tls.enabled=true
