Configure HTTPS
This section describes how to configure https to allow secure communication to the OpenIAM UI.
If opted to not install the rProxy during the RPM installation process, then install it now. The guide on how to install OpenIAM rProxy can be found here.
To configure HTTPS, perform the following steps.
- Copy our certs to
/etc/pki/tls/certs/. - Copy private key to
/etc/pki/tls/private/. - Remove the existing
mod_openiam.conffile from/etc/httpd/conf.dor from the location based on the installation.
mv /etc/httpd/conf.d/ssl.conf /etc/httpd/conf.d/ssl.conf_not_used
- Remove no ssl configuration.
mv /etc/httpd/conf.d/mod_openiam.conf /etc/httpd/conf.d/mod_openiam.conf_not_used
- Copy OpenIAM ssl configuration example.
cp /usr/share/doc/mod_openiam/conf.d/mod_openiam_ssl.conf /etc/httpd/conf.d/
- Modify the following in file
/etc/httpd/conf.d/mod_openiam_ssl.conf.
SSLCertificateFile /etc/pki/tls/certs/super_openiam_com.crtSSLCertificateKeyFile /etc/pki/tls/private/super_openiam_com.keySSLCACertificateFile /etc/pki/tls/certs/gd_bundle.crt#SSLCertificateFile /etc/pki/tls/certs/localhost.crt#SSLCertificateKeyFile /etc/pki/tls/private/localhost.key#SSLCACertificateFile /etc/pki/tls/certs/ca-bundle.crt
Files from your certificate provider, such as GoDaddy, are:
super_openiam_com.crt;super_openiam_com.key;gd_bundle.crt.
Now you can restart Apache.
systemctl restart httpd
Make sure you have port 80 for http (or 443 for https) open. If not, you can use the following firewall rules.
sudo firewall-cmd --permanent --zone=public --add-port=80/tcpsudo firewall-cmd --zone=public --add-service=httpsudo firewall-cmd --reload
sudo firewall-cmd --permanent --zone=public --add-port=443/tcpsudo firewall-cmd --zone=public --add-service=httpssudo firewall-cmd --reload
