Configuring HTTPS on Docker
A first step in securing your deployment is to enable HTTPS in your docker installation. You will need to follow the process described below. The high-level steps include the following.
- Generate a certificate from you CA. (You can use a use a self-signed if this is a non-production environment).
- Deploy the certificate.
- Restart OpenIAM.
- Validate that the HTTPS works.
From your CA, please generate a certificate for your deployment. You will need the follow:
- Key file.
- Certificate file.
- SSL certificate chain file or SSL CA File.
Update rProxy user access
The rProxy Docker container runs as user rproxy
with uid = 75001
in the Docker container. Since the rproxy Docker container is not running as root
, it has no access by default to the /opt/openiam/httpd
directory. To configure access to it:
- The user 'rproxy' with uid = 75001 should be created on the host machine.
- The directory
/opt/openiam/httpd
should be configured to have read access for userrproxy
The rProxy Docker container can then map directories under /opt/openiam/httpd
to Docker volumes and use certificates and keys stored there.
sudo groupadd -g 75001 rproxysudo useradd --shell /sbin/nologin -u 75001 -g 75001 rproxy
Create the folders to deploy the certificate on the OpenIAM host
By default, the certificates and keys are stored in the /opt/openiam/httpd/ssl-certs
and the /opt/openiam/httpd/ssl-keys
respectively. This location is defined in the openiam-docker-compose/3.2/rproxy-ssl/docker-compose.yaml
file. Otherwise, if you change this location, the certificates and keys must be stored in these two folders.
Create the required certificate folders using the steps described below.
sudo mkdir /opt/openiamsudo mkdir /opt/openiam/httpdsudo mkdir /opt/openiam/httpd/ssl-certssudo mkdir /opt/openiam/httpd/ssl-keyssudo chown -R rproxy /opt/openiam/httpdsudo chmod -R 755 /opt/openiam/httpd/ssl-certssudo chmod -R 700 /opt/openiam/httpd/ssl-keys
Next copy the certificate files to the appropriate directories, if you are using the above defaults.
Update OpenIAM configuration
The use the certificates and to enable https, please update the following variables in the openiam-docker-compose/env.sh
Variable Name | Description |
OPENIAM_RPROXY_HTTP | Set this to 0 enable HTTPS. Set it to 1 to disable https. |
OPENIAM_SSL_CERT | Name of the certificate file, i.e. mycert.crt . Do not include the path. |
OPENIAM_SSL_CERT_KEY | Name of the key file; i.e. mycert.key . Do not include the path. |
OPENIAM_SSL_CA | Name of the SSL CA certificate. This file should be in the same folder as the certificate file. |
In a multi-node environment, copy these files to other Docker nodes in the same directories too. Alternatively, configure the /opt/openiam/httpd
directory so that it can be accessed from multiple nodes.
For these changes to take effect, you need to re-start OpenIAM. Use the ./shutdown.sh
and ./start.sh
utilities on the docker compose directory as you did during the installation process. Ensure that all services have stopped before re-starting.
Validating the configuration
There are several ways to validate that your configuration for enabling SSL is working correctly. These are described below.
Inspect the rProxy container
Get the container ID of the rProxy by running the following.
docker ps | grep rproxy
Use the container ID from the output to check the Apache webserver and rProx logs.
docker logs -f [container id]
Use the container ID in conjunction with the docker inspect
to validate that our certificate directories have been mounted.
docker inspect [container id]
You will a section that looks like below.
"Mounts": [{"Type": "bind","Source": "/opt/openiam/httpd/ssl-certs","Destination": "/opt/openiam/httpd/ssl-certs","Mode": "","RW": true,"Propagation": "rprivate"},{"Type": "bind","Source": "/opt/openiam/httpd/ssl-keys","Destination": "/opt/openiam/httpd/ssl-keys","Mode": "","RW": true,"Propagation": "rprivate"}
Testing using Curl
You can test the https URL using curl as shown below
curl -k https://localhost/idp/actuator/health
If https is enabled, you will see a command shown below.
{"status":"UP"}[root@iam-docs openiam-docker-compose]
From the browser
The final validation is the access the OpenIAM application from the UI using either one of the following application URLs.
https://[host name]/webconsolehttps://[host name]/selfservice
If this is this the first time that you are logging using SSL, then the system will ask you the set another content provider. Configure it as you did during the installation process, except ensure that the Is SSL?
is set to Yes
as shown in the image below.
