Upgrading from versions 4.2.1.9-4.2.1.10 to version 4.2.1.11 in RPM
This document will guide the users on how to upgrade to version 4.2.1.11 from previous 4.2.1.9-4.2.1.10 versions.
Starting with OpenIAM version 4.2.1.4 upgrade.sh is a part of the RPM installation, so the upgrading process involves simple steps, as shown below.
- Set the parameter in the env.sh.
export UPGRADE_TO_VERSION=""
- Run the following command.
- Check all the services are up and running, by running the following command.
- Once all the services are up and running, login to OpenIAM and navigate to Administration > About OpenIAM.
The build version must be updated to 4.2.1.11.
Note: You must update connector if you use newer versions of the product. It is recommended to use the latest connector version.
All .NET/PS connectors versions as at 5.24.0.0 version are backward compatible, hence updating it will not disrupt operation of OpenIAM versions 4.2.0 and higher.
