Installation with Internet access
The RPM installation for OpenIAM 4.2.1.12+ now supports Enterprise Linux 9 (EL9). During the installation process, you will be prompted to install MariaDB RDBMS as the default database.
Database Recommendations
- MariaDB Usage: MariaDB is suitable for Demo, Proof-of-Concept (POC), or small-scale deployments. However, for production environments, we strongly recommend using a corporate-standard database that aligns with your organization’s IT policies and is fully supported operationally.
- MariaDB in Production: If you choose to use MariaDB in a production setting, ensure that:
- It is properly sized for your workload
- It is deployed in a high-availability (HA) configuration to enhance reliability.
Using an Existing Database Infrastructure
If you already have a database infrastructure you prefer to use, select N when prompted during the installation. This option allows you to integrate OpenIAM with your preferred database system.
The following sections will guide you through the OpenIAM installation process step by step.
Download the RPM installer using the following command.
curl https://download.openiam.com/release/enterprise/4.2.1.13/rpm/openiam-4.2.1.13.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpmOnce the download is complete, install OpenIAM using the following command. This step will also update the initial ulimit settings, which are required for the subsequent installation process
You should see the output like one given below.
openiam/openiam/utils/openiam/utils/autodb.shopeniam/utils/autoinit.shopeniam/utils/cassandra_tombstones_issue_fix.shopeniam/utils/cluster_healthcheck.shopeniam/utils/elasticsearch/openiam/utils/elasticsearch/archive.shopeniam/utils/elasticsearch/default.policy.diffopeniam/utils/elasticsearch/elasticsearchopeniam/utils/elasticsearch/elasticsearch.serviceopeniam/utils/elasticsearch/init.shopeniam/utils/elasticsearch/jvm.optionsopeniam/utils/graph/openiam/utils/graph/alter_table.cqlopeniam/utils/graph/cassandra.serviceopeniam/utils/graph/cassandra.yamlopeniam/utils/graph/gremlin-server.yamlopeniam/utils/graph/healthcheck.groovyopeniam/utils/graph/init.shopeniam/utils/graph/janusgraph-cql.propertiesopeniam/utils/init.shopeniam/utils/init_vault_cluster.shopeniam/utils/sas/openiam/utils/sas/init.shopeniam/utils/shutdown.shopeniam/utils/start-openiam.shopeniam/utils/start.sh...
Your VM will reboot to apply changes to ulimit. After it reboots, reconnect to your VM by executing the following command and providing your credentials when prompted.
Type y and press Enter.
The system will download additional files, extract them locally, update your repository, and install essential base packages. You will see output similar to the snippet below.
Initialize openiamDoes this box have Internet access ? [y/n]:yIt is default configuration in env.confDownload file openiamrepo.tar.gz from OpenIAM websiteDownload file backend.tar.gz from OpenIAM websiteDownload file frontend.tar.gz from OpenIAM websiteopeniamrepo/openiamrepo/mariadb/openiamrepo/mariadb/perl-MIME-Base64-3.15-396.el8.x86_64.rpmopeniamrepo/mariadb/perl-Math-BigInt-1.9998.11-7.el8.noarch.rpmopeniamrepo/mariadb/perl-Pod-Usage-1.69-395.el8.noarch.rpmopeniamrepo/mariadb/mariadb-backup-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpmopeniamrepo/mariadb/perl-Net-SSLeay-1.88-2.module+el8.6.0+13392+f0897f98.x86_64.rpmopeniamrepo/mariadb/perl-IO-1.38-422.el8.x86_64.rpmopeniamrepo/mariadb/perl-DBD-MySQL-4.046-3.module+el8.1.0+2938+301254e2.x86_64.rpmopeniamrepo/mariadb/mariadb-errmsg-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpmopeniamrepo/mariadb/perl-interpreter-5.26.3-422.el8.x86_64.rpmopeniamrepo/mariadb/perl-Term-ANSIColor-4.06-396.el8.noarch.rpmopeniamrepo/mariadb/perl-Time-Local-1.280-1.el8.noarch.rpmopeniamrepo/mariadb/perl-Unicode-Normalize-1.25-396.el8.x86_64.rpmopeniamrepo/mariadb/perl-Scalar-List-Utils-1.49-2.el8.x86_64.rpmopeniamrepo/mariadb/perl-Mozilla-CA-20160104-7.module+el8.3.0+6498+9eecfe51.noarch.rpmopeniamrepo/mariadb/compat-openssl11-1.1.1k-4.el9.x86_64.rpmopeniamrepo/mariadb/mariadb-connector-c-3.1.11-2.el8_3.x86_64.rpmopeniamrepo/mariadb/perl-podlators-4.11-1.el8.noarch.rpmopeniamrepo/mariadb/perl-Exporter-5.72-396.el8.noarch.rpmopeniamrepo/mariadb/mariadb-server-utils-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpmopeniamrepo/mariadb/perl-Math-Complex-1.59-422.el8.noarch.rpmopeniamrepo/mariadb/perl-Text-ParseWords-3.30-395.el8.noarch.rpmopeniamrepo/mariadb/perl-Digest-MD5-2.55-396.el8.x86_64.rpmopeniamrepo/mariadb/libaio-0.3.112-1.el8.x86_64.rpmopeniamrepo/mariadb/perl-File-Path-2.15-2.el8.noarch.rpmopeniamrepo/mariadb/mariadb-server-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpmopeniamrepo/mariadb/perl-PathTools-3.74-1.el8.x86_64.rpmopeniamrepo/mariadb/perl-Pod-Escapes-1.07-395.el8.noarch.rpmopeniamrepo/mariadb/perl-libs-5.26.3-422.el8.x86_64.rpmopeniamrepo/mariadb/perl-Socket-2.027-3.el8.x86_64.rpmopeniamrepo/mariadb/perl-Carp-1.42-396.el8.noarch.rpmopeniamrepo/mariadb/perl-threads-shared-1.58-2.el8.x86_64.rpmopeniamrepo/mariadb/mariadb-10.3.39-1.module+el8.8.0+19673+72b0d35f.x86_64.rpmopeniamrepo/mariadb/perl-IO-Socket-IP-0.39-5.el8.noarch.rpm...================================================================================Package Architecture Version Repository Size================================================================================Installing:m4 x86_64 1.4.19-1.el9 appstream 294 ktelnet x86_64 1:0.17-85.el9 appstream 63 kTransaction Summary================================================================================Install 2 PackagesTotal download size: 357 kInstalled size: 703 kDownloading Packages:(1/2): telnet-0.17-85.el9.x86_64.rpm 327 kB/s | 63 kB 00:00(2/2): m4-1.4.19-1.el9.x86_64.rpm 1.0 MB/s | 294 kB 00:00--------------------------------------------------------------------------------Total 988 kB/s | 357 kB 00:00Running transaction checkTransaction check succeeded.Running transaction testTransaction test succeeded.Running transactionPreparing : 1/1Installing : m4-1.4.19-1.el9.x86_64 1/2Installing : telnet-1:0.17-85.el9.x86_64 2/2Running scriptlet: telnet-1:0.17-85.el9.x86_64 2/2Verifying : telnet-1:0.17-85.el9.x86_64 1/2Verifying : m4-1.4.19-1.el9.x86_64 2/2Installed:m4-1.4.19-1.el9.x86_64 telnet-1:0.17-85.el9.x86_64Complete!workflow.jarsynchronization.jarreconciliation.jaropeniam-esb.jaridm.jargroovy-manager.jaremail-manager.jardevice-manager.jarauth-manager.jarbusiness-rule-manager.jarsas-manager.jarsas-lib.zipidp.waropeniam-ui-static.warselfservice-ext.warselfservice.warwebconsole.warreportviewer.war
Please answer Y if you would like to use the local MariaDB RDBMS as a database server. To use another database, please enter N. This question enables the installation of MariaDB so that it can be used later in the installation process.
4.1. If you answered Y, the MariaDB installer will prepare the files needed to install and configure MariaDB. Once this process is complete, you will be asked the questions below. Answer them and proceed to the next step.
Enter current password for root (enter for none):- Press Enter, as no password has been set yet.
- You will see the following confirmation message:
OK, successfully used password, moving on...Setting the root password ensures that nobody can log into the MariaDBroot user without the proper authorisation.
Set root password? [Y/n]-> Pressybutton and afterEnter
- Type Y and press Enter to set a password for the MariaDB root user.
New password:->- Enter a secure password for the MariaDB root user.
- Note: You will need this password later in the installation process.
- Type the same password as in the previous step and press Enter.
Re-enter new password:- Type the same password as in the previous step and press Enter.
Remove anonymous users? [Y/n]- Type Y and press Enter to remove anonymous database users.
- This enhances security by ensuring only authenticated users can access MariaDB.
Disallow root login remotely? [Y/n]- Type Y and press Enter to prevent remote root login.
- This reduces the risk of unauthorized access.
Remove test database and access to it? [Y/n]- Type Y and press Enter to delete the default test database.
- This prevents potential security risks from an unused database.
Reload privilege tables now? [Y/n]- Type Y and press Enter to apply the changes immediately.
The snippet below provides a view of what you can expect to see in this part of the installation. Note, that for successful installation it is required to set a password for the root user in MariaDB.
NOTE: RUNNING ALL PARTS OF THIS SCRIPT IS RECOMMENDED FOR ALL MariaDBSERVERS IN PRODUCTION USE! PLEASE READ EACH STEP CAREFULLY!In order to log into MariaDB to secure it, we'll need the currentpassword for the root user. If you've just installed MariaDB, andyou haven't set the root password yet, the password will be blank,so you should just press enter here.Enter current password for root (enter for none):OK, successfully used password, moving on...Setting the root password ensures that nobody can log into the MariaDBroot user without the proper authorisation.Set root password? [Y/n] openiamSet root password? [Y/n] YNew password:Re-enter new password:Password updated successfully!Reloading privilege tables..... Success!By default, a MariaDB installation has an anonymous user, allowing anyoneto log into MariaDB without having to have a user account created forthem. This is intended only for testing, and to make the installationgo a bit smoother. You should remove them before moving into aproduction environment.Remove anonymous users? [Y/n] y... Success!Normally, root should only be allowed to connect from 'localhost'. Thisensures that someone cannot guess at the root password from the network.Disallow root login remotely? [Y/n] y... Success!By default, MariaDB comes with a database named 'test' that anyone canaccess. This is also intended only for testing, and should be removedbefore moving into a production environment.Remove test database and access to it? [Y/n] y- Dropping test database...... Success!- Removing privileges on test database...... Success!Reloading the privilege tables will ensure that all changes made so farwill take effect immediately.Reload privilege tables now? [Y/n] y... Success!Cleaning up...All done! If you've completed all of the above steps, your MariaDBinstallation should now be secure.Thanks for using MariaDB!
After MariaDB has been installed, the installer will move forward to a variety of infrastructure services such as the Vault, Redis, RabbitMQ and Cassandra, which is the storage for the graph database used in OpenIAM. This process will take 4-5 min.
The snippet below, which follow the installation of MariaDB, shows a certificate being generated and the vault being initialized.
...Certificate request self-signature oksubject=C=US, ST=NY, L=NY, O=OPENIAM, OU=PRODUCTION, CN=localhostWarning: -clcerts option ignored with -exportwriting RSA keyWarning: use -cacerts option to access cacerts keystoreCertificate was added to keystore[Storing /usr/local/openiam/jdk/lib/security/cacerts]Created symlink /etc/systemd/system/multi-user.target.wants/etcd.service → /usr/lib/systemd/system/etcd.service.Starting etcd...Created symlink /etc/systemd/system/multi-user.target.wants/openiam-vault.service → /etc/systemd/system/openiam-vault.service.Starting vault...Wait vault service to wakeupInitializing vault. This will only happen once. This will output the root token and unseal keys. Save them!
The installer will ask several questions during the initialization process. For most questions, a default value has been provided to simplify the effort for users new to OpenIAM. The sections which requires input from the installer are marked with the following message in the console:
OpenIAM has two schemas which are created by default: openiam and activiti. The openiam schema is the primary schema used by the platform and it stores a variety of information ranging from policies to user profile information and more. activiti is used to store information about workflows and their execution. The first set of questions raised by the installer are related to the creation of database users for each schema. Each question and its intent are listed below.
Set OpenIAM username for schema openiam, default: idmuser | This is the DB username that will be used to manage the openiam OpenIAM schema. This is the primary schema in the solution data related to OpenIAM are stored. Users will be used by the OpenIAM application to communicate with the database. The default value is idmuser. |
Set OpenIAM password for schema openiam, default: idmuser | This is the password that will be used for the username which was provided in the previous step. The default value is: idmuser. |
Set OpenIAM username for schema activiti. For MySQL it will be the same as for openiam, default: idmuser | This is the DB username that will be used to manage the activiti schema. Users will be used by OpenIAM application to communicate with the database. Default value is idmuser. |
Set OpenIAM password for schema activiti. For MySQL it will be the same as for openiam, default: idmuser | This is the password for the user associated with the activiti schema. The default value is idmuser. |
DatabaseSet OpenIAM username for schema 'openiam' , default: idmuserSet OpenIAM password for schema 'openiam' , default: idmuserSet OpenIAM username for schema 'activiti'., default: activitiSet OpenIAM password for schema 'activiti'., default: activitiSet OpenIAM password for RabbitMQ message broker, default: passwd00Set OpenIAM password for Redis., default: passwd00User to Access ElasticSearch. If you don't change it on the ES server side, leave it as elastic, default: elasticPassword for elastic to access ElasticSearch, default: VlyXHUBDuhgv6BTKjTz7TumtBZL8Zbmu
OpenIAM uses RabbitMQ as a message broker. RabbitMQ is the primary transport service used within the OpenIAM application. Services are loosely coupled, and they communicate with each other through the message broker. Cross service communication is encrypted.
Memory cache password
- End user web session.
- Database object cache.
Elasticsearch credentials
Elasticsearch search is used by OpenIAM to enable fast searching of frequently used data. As with the components above, access to Elasticsearch is secured through its own set of credentials. You are prompted for this information as shown below.
User to Access ElasticSearch. If you don't change it on the ES server side, leave it as elastic, default: elasticOpenIAM password for elastic user to access ElasticSearch: KtmHIv4yEhb4w7VRxhveTIDTHAgPfNmY
Cassandra
After processing the above information, the installer will then install Cassandra. Cassandra is the storage engine for Janus Graph DB. You will see output like the example below during this step.
Synchronizing state of cassandra.service with SysV service script with /usr/lib/systemd/systemd-sysv-install.Executing: /usr/lib/systemd/systemd-sysv-install enable cassandraCreated symlink /etc/systemd/system/default.target.wants/cassandra.service → /etc/systemd/system/cassandra.service.0error: No nodes present in the cluster. Has this node finished starting up?-- StackTrace --java.lang.RuntimeException: No nodes present in the cluster. Has this node finished starting up?...Waiting for cassandra1Datacenter: datacenter1=======================Status=Up/Down|/ State=Normal/Leaving/Joining/Moving-- Address Load Tokens Owns (effective) Host ID RackUN 127.0.0.1 73.52 KiB 256 100.0% 5a7c7a99-aeaf-4576-9863-f226a7867ef0 rack1Cassandra aliveCassandra is ready to use. Continue...
Use default value if this is new installation. If you are doing an update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0 | If this install is an upgrade from an existing deployment, then the current version is important as it will determine which scripts need to be applied to upgrade the schema to the current version. If this is a new deployment, you can leave this blank. |
Possible values: MySQL, Postgres, MSSQL, Oracle. Type of the database that you are going to use with OpenIAM. The RDBMS have to be already installed, default: MySQL | Select the type of database that you will be using as the OpenIAM product repository. You can leave this blank if you will be using either MariaDB or MySQL. If you are using either PostgreSQL, Oracle or Microsoft SQL server, enter one the following values based on your database type: postgres, oracle, mssql. |
| Do you want to initialize OpenIAM Schema and Users? Select this if you are not created schema and users in RDBMS yet. Super user (root) password will be required [y/n] | If Y then the installer will create schemas in the database and correspond with RDBMS users as well. For Oracle/MSSQL it will generate an SQL script that must be performed manually. |
Enter username for Super user (for MySQL this is root), default: root | The installer needs a super user account or equivalent which has the privileges to create new schema, users, tables, etc. |
Enter password for super user (sa or root, depend on the DB type), default: | Enter the password for account provided in the last step. |
Do you use AWS RDS MariaDB? If Yes, make sure the RDS DB instance has the parameter log_bin_trust_function_creators = 1 [y/n]: | Select N if AWS RDS MariaDB is not being used for this deployment. |
This is the hostname of where the OpenIAM core database is, default: localhost | Enter the host or DNS name of the server where the primary OpenIAM database will be deployed. |
This is the hostname of where the Activiti database is, default: localhost | Enter the host or DNS name of the server where the workflow database will be deployed. |
This is the port of where the Activiti database is. If using MariaDB, this is most likely 3306, default: 3306 | Enter the port number used by the database server hosting the workflow database. |
Please validate information below---------------------------------FLYWAY_BASELINE_VERSION=0.0.0.0FLYWAY_OPENIAM_DATABASE_NAME=openiamFLYWAY_ACTIVITI_DATABASE_NAME=activitiFLYWAY_OPENIAM_HOST=localhostFLYWAY_OPENIAM_PORT=3306FLYWAY_ACTIVITI_HOST=localhostFLYWAY_ACTIVITI_PORT=3306FLYWAY_DATABASE_TYPE=mysqlDatabase will be initialized=YRoot (Db admin) user name=rootRoot (Db admin) user password=openiam---------------------------------Please validate your input above, if you are OK with that enter 'y'. To repeat an information collecting procedure enter 'n' :y
If you need to correct any answer, please enter N.
Once you select Y, the installer will generate the database schema. Internally, this step is handled by a component called Flyway. Flyway is a database schema management and versioning utility. It's used to generate the schema as well as upgrade from one version to another.
Install reverse proxy
After, the system may ask whether you want to update httpd software. httpd is an Apache webserver used to host websites and applications, as well as process and provide response to requests. Enter y for the question below and proceed with installation.
The OpenIAM RPM installer will continue with initialization and apply the SQL scripts which are required for successful startup. The OpenIAM services will automatically run the application stack after successful initialization and will show you the current stack status. Usually, startup takes around 10-15 minutes. You can view the status of the system as it's coming up using the command line tools described below in OpenIAM components and Status.
Please, ignore the
HTTP request sent, awaiting response... 404 Not Found2023-11-09 21:04:58 ERROR 404: Not Found.
Check the startup process
The containers may take 8 to 15 minutes (depending on your environment) to start up completely. You can watch the startup process using the command below. Note that the UI container will take some time and be among the last to start up as it has dependencies on other components being up first.
Monitor the startup process
You will see output like the example below:
Openiam Status report Fri Feb 21 09:49:32 PM UTC 2025[OK] - openiam-esb - Service working. Application status: [ UP ][OK] - workflow - Service working. Application status: [ UP ][OK] - groovy-manager - Service working. Application status: [ UP ][OK] - idm - Service working. Application status: [ UP ][OK] - reconciliation - Service working. Application status: [ UP ][OK] - email-manager - Service working. Application status: [ UP ][OK] - auth-manager - Service working. Application status: [ UP ][OK] - business-rule-manager - Service working. Application status: [ UP ][OK] - device-manager - Service working. Application status: [ UP ][OK] - synchronization - Service working. Application status: [ UP ][OK] - openiam-ui - Service working. Application status: [ UP ]
You should see output like the example below
HTTP/1.1 200Date: Fri, 21 Feb 2025 21:49:04 GMTServer: Apache/2.4.61 (Red Hat Enterprise Linux) OpenSSL/3.2.2Report-To: { "group": "csp-endpoint", "max_age": 10886400, "endpoints": [ { "url": "http://127.0.0.1/selfservice/csp/report" } ] }Content-Security-Policy: default-src 'self' blob: data: 'unsafe-inline' 'unsafe-eval'; script-src 'self' 'unsafe-inline' 'unsafe-eval' apis.google.com; style-src 'self' 'unsafe-inline' 'unsafe-eval' *; form-action 'self' 'unsafe-inline' 'unsafe-eval' *; img-src 'self' data: https://chart.googleapis.com; font-src 'self' *; report-uri /selfservice/csp/report; report-to csp-endpointAccess-Control-Allow-Origin: *X-Frame-Options: sameoriginX-Content-Type-Options: nosniffX-XSS-Protection: 1; mode=blockCache-Control: no-cachePragma: no-cacheExpires: Wed, 31 Dec 1969 23:59:59 GMTX-UA-Compatible: IE=EmulateIE10x-openiam-force-auth: falsex-openiam-login-uri: /idp/loginContent-Type: text/html;charset=UTF-8Content-Language: en-USContent-Length: 4970Set-Cookie: SESSION=OWJiZDkwMTMtMDNmZC00NThmLWI5ZWEtYTljYzE4N2VhMTZh; Path=/; HttpOnly; SameSite=LaxVary: Accept-Encoding
Use the following credentials for the first time login:
| Content Provider Name | You can think of a content provider as an “alias” which represents a domain. This is described in more detail in the OpenIAM documentation. For this setup, please enter a value such as : Default CP |
Post installation information
Using the OpenIAM command line utility
Check status
To check the status of the components or to confirm that the system is up, please use the following command:
Check service logs
To check current logs of any service you can use the following command. You can get the services using the following command: openiam-cli log <service_name>.
Start and stop
You can start the application using the following command.
Checking the health of the application
Health checks can be used by your monitoring systems to verify the status of OpenIAM.
Use the following URL to validate ESB.
curl http://localhost:9080/openiam-esb/actuator/health
Use the following URL to validate the UI.
curl -k http://localhost:9080/idp/actuator/health
Core services and Default Memory configuration
| email-manager | The service that provides Sending and Receiving email functionality | 256m |
| auth-manager | The service that provides Authorization functionality | 1024m |
| openiam-ui | This provides the OpenIAM UI running on an Apache Tomcat server | 2048m |
Troubleshooting
It is possible to receive a timeout error during the installation of Elasticsearch during initialization. This issue can be rectified by setting the SELinux mode to Permissive. Please refer to Red Hat's documentation for Changing SELinux states and modes.
In case there is a need for VM reboot or restarting an application, make sure to shut down OpenIAM with openiam-cli stop command, as shown above. Otherwise, the vault may seal, and the application may fail to start.
