Workflow tab
The Workflow tab allows the configuration of workflow properties.
Workflow Tab
FieldDescription
Activiti UI Thread FrequencyThis option allows setting the frequency of processing or updating the UI thread in the Activiti system.
Access certification helper scriptProvides helper logic used during access certification processes, such as preparing data, evaluating conditions, or supporting certification decisions.
Workflow request creation helper scriptExecutes custom logic during workflow request creation, allowing validation, data enrichment, or dynamic request initialization.
Edit user workflow approver calculation scriptDynamically determines the approvers for workflows related to editing existing user information.
Basic workflow approver calculation scriptCalculates the approver list for standard workflows based on predefined rules and context.
Access management approver scriptDetermines approvers for access management requests, such as role, group, or entitlement assignments.
New user workflow approve calculation scriptCalculates the approvers required for new user onboarding workflows.
RBAC workflow approver calculation scriptDetermines approvers for role-based access control (RBAC) workflows, based on roles, policies, or organizational structure.
Termination approver association scriptAssociates the appropriate approvers with user termination workflows.
Fill profile info workflow association scriptDefines how the workflow for completing or updating user profile information is associated and triggered.
Revoke roles and groups after employee terminationExecutes logic to automatically remove assigned roles and group memberships after an employee is terminated.
Default Approver ResourceIf no approver associations can be determined for a workflow, the approver association of this resource name will be used.
Default Workflow ApproverThe default approver for all workflows if no approval can be determined.
Approver Association and Custom Approver MergingIf the feature is set to 'true,' the administrator can associate specific approvers with particular stages or actions within a process and allows for the customization and merging of approvers based on needed rules or conditions.
New Hire Approver Association OrderThe order in which the new hire event is being approved.
Provisioning after start date initializerInitializes and controls provisioning actions that should be triggered only after a user’s start date is reached, ensuring that accounts, roles, and access are created at the appropriate time.
Use batch task for handling of expiring accessIf checked, it enables administrators or users to use a batch task for handling or managing the expiration of access operations.
Number of days before access expires to re-requestSets the period in days for which the access request is valid.
Base URL for the formation of a link to renew access requestThe URL used as a base when renewing access requests.
Use approver association or role/group instead of resourceIf the property is set to 'true', then the approver association workflow for the group or role will be used, instead of the resource one.
Default Position Id AttributeThe field allows setting the attribute as the default identifier for positions (roles, groups, organizations) in the system.
Default Secondary Position Id AttributeThe field allows setting the attribute as the default identifier for secondary positions in the system.
Initiate access requests for selected roles/groups (New Hire / Edit user)If set to 'true,' it enables initiating the access request for selected roles/groups for new hire or edit user workflows.
Workflow 'Master' resourceThe field refers to a primary resource within a workflow.
Include in Position Change request only role and groups requested from the service catalogIf checked, this feature allows including the request for position change for only roles/groups in the service catalog.
Roles which members are allowed to cancel and delegate requests for any userHere one can choose a role to cancel and delegate requests.
Roles which members are allowed to revoke access for any userHere one can choose a role to revoke access for users. This will extend the default setting where superadmin role members can revoke access, a manager can revoke access for their direct employees and a user can do it for themself.
Extra Information fields on Task view pageAllows adding extra fields with information necessary for the task view page.
When user is getting terminated, remove their access (if 'false' then access will be end-dated)Determines whether a user’s access is immediately removed upon termination or, if set to false, retained until the configured end date.
Terminate user via the approver association flowControls user termination by routing the termination request through an approver-based workflow, ensuring that required approvals are obtained before deprovisioning and termination actions are executed.
