The URL `docs-4.2.2/admin/12-administration/1-sysconfig` does not exist. This page may have been moved, renamed, or deleted.
- [Administration Guide](https://docs.openiam.com/administration-guide/admin.md)
- [Run a synchronization on a schedule](https://docs.openiam.com/administration-guide/automation/batch-tasks/schedule-a-synchronization.md)
- [Caddie — Access Review Assistant](https://docs.openiam.com/administration-guide/caddie.md)
- [Plan and scope a campaign](https://docs.openiam.com/administration-guide/governance/certification/plan-and-scope-a-campaign.md)
- [Create a user campaign](https://docs.openiam.com/administration-guide/governance/certification/create-a-user-campaign.md)
GET https://docs.openiam.com/administration-guide/admin.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/administration-guide/admin.md`).
