Troubleshooting guide for RPM
In the event of an OpenIAM installation failure, users can troubleshoot and identify potential issues by collecting and examining logs. Below is a general guide on how to collect logs for failed installations and individual service failures, which is the first step in troubleshooting.
1. First level: Start by analyzing the ESB logs for errors.
2. Second level: If no issues are found in ESB, proceed to analyze logs for services such as IDM, Workflow, Authentication, Synchronization, Reconciliation, Email, etc.
3. Final step: Only if no issues are found in the first two levels, then check the UI log.
Collecting OpenIAM installation logs
If the OpenIAM installation fails, retrieve the init.log file from the following directory.
cd /usr/local/openiam[root@rhel9 openiam]# ls -lrth | grep init-rw-r--r--. 1 root root 222K Jan 29 13:54 init.log
Collecting logs for individual failed services
To collect logs for individual services, navigate to the logs directory and list the available log files.
cd /usr/local/openiam/logs[root@rhel9 logs]# ls -lrth
Example log files are the following.
-rwxrwxrwx. 1 root root 0 Jan 29 13:49 vault.out-rw-r--r--. 1 openiam openiam 41K Feb 2 10:19 business-rule-manager.log-rw-r--r--. 1 openiam openiam 41K Feb 2 10:19 reconciliation.log-rw-r--r--. 1 openiam openiam 41K Feb 2 10:19 synchronization.log-rw-r--r--. 1 openiam openiam 41K Feb 2 10:19 groovy-manager.log-rw-r--r--. 1 openiam openiam 53K Feb 2 10:19 workflow.log-rw-r--r--. 1 openiam openiam 43K Feb 2 10:19 device-manager.log-rw-r--r--. 1 openiam openiam 86K Feb 2 10:21 idm.log-rw-r--r--. 1 openiam openiam 61K Feb 2 10:21 email-manager.log-rw-r--r--. 1 openiam openiam 61K Feb 2 10:21 auth-manager.log-rw-r--r--. 1 openiam openiam 168K Feb 2 10:51 openiam-esb.log
Collecting OpenIAM UI logs
To retrieve catalina.out log for the OpenIAM UI, navigate to the following directory.
cd /usr/local/openiam/ui/logs
To list Catalina logs use the following.
[root@rhel9 logs]# ls -lrth | grep catalina-rw-r-----. 1 openiam openiam 927K Jan 29 18:50 catalina.2025-01-29.log-rw-r-----. 1 openiam openiam 309K Jan 30 05:56 catalina.2025-01-30.log-rw-r-----. 1 openiam openiam 1.8M Feb 2 10:23 catalina.out-rw-r-----. 1 openiam openiam 272K Feb 2 10:23 catalina.2025-02-02.log
OpenIAM CLI commands for individual service logs
To check logs for specific services, use the following OpenIAM CLI commands.
openiam-cli log openiam-esbopeniam-cli log idmopeniam-cli log openiam-uiopeniam-cli log workflowopeniam-cli log auth-manageropeniam-cli log device-manageropeniam-cli log reconciliationopeniam-cli log synchronizationopeniam-cli log groovy-manageropeniam-cli log email-manager
Checking Journalctl logs for individual services
To check service logs using journalctl, use the following commands.
journalctl -u openiam-esbjournalctl -u idmjournalctl -u openiam-uijournalctl -u workflowjournalctl -u auth-managerjournalctl -u device-managerjournalctl -u reconciliationjournalctl -u synchronizationjournalctl -u groovy-managerjournalctl -u email-manager
Writing and Sharing Live-Log Files
When troubleshooting, it’s usually best to capture and share only the logs that are directly related to the issue. Instead of sending the full application log (which can be very large and include unrelated information), you can create a new file that contains only the events from the moment you reproduce the problem.
Steps on Linux
- Open a terminal.
- Run the following command to start writing the live logs into a temporary file, for example for ESB logs:
tail -f /usr/local/openiam/logs/openiam-esb.log > /tmp/esb_live_issue.txt
tail -f continuously reads the end of the main log file and saves everything into a new file under /tmp.
While this command is running, go back to the application and perform the action that causes the problem.
Once the error happens, stop the command by pressing Ctrl + C.
Now you’ll find the captured log file at:
6. Share this file with us.
Why this helps
By following this process, the file you share will only contain logs generated during the failed action, rather than the entire application history. This makes the investigation quicker and avoids sending unnecessary data.
Which file shell I send to OpenIAM support?
- openiam-esb.log – This is the main service bus log, and it’s almost always useful. Please include this file with your report regardless of the issue.
- idm.log – Use this when the problem is related to provisioning, identity management operations, or user account changes.
- email-manager.log – Share this when the issue involves email delivery (e.g., notifications not being received).
- synchronization.log – Relevant if the issue happens during a synchronization process.
- reconciliation.log – Needed when reconciliation tasks fail or produce unexpected results.
- business-rule-manager.log – Share this (together with idm.log) if you observe that business rules are not being applied correctly.
- auth-manager.log – Useful when a user cannot see menus, is missing access to certain screens they should have, or during provisioning troubleshooting where access rights are involved.
- device-manager.log – Share if problems occur in device-related operations.
- groovy-manager.log – Usually not helpful for troubleshooting. Please do not send this log by default; we will request it only if needed.
- workflow.log – Provide this when you experience issues with submitting or approving requests, user access certification, or completing review actions — essentially, anything related to workflows initiated from the self-service portal.
- ldap-connector-rabbitmq.log – Share this only if the issue is related to provisioning or synchronization through the LDAP connector (if your system is configured to use it).
General Guidance
Always include openiam-esb.log along with the specific log file related to your operation.
If you’re unsure which log file to share, just consider which kind of operation you performed and which OpenIAM service that operation corresponds to — use common sense to pick the relevant log. For more complex issues (e.g., involving workflows, business rules, or provisioning), it may be necessary to include two or more logs together.
Do not send unnecessary logs (like groovy-manager.log,device-manager.log) unless specifically requested, as they rarely provide useful information.
By choosing the right log file, you help us quickly identify what went wrong and speed up the resolution process.
Using the tail command to capture relevant logs
When troubleshooting or preparing for performance testing, you might not need to capture full application log files. Log files can grow very large, making them difficult to share and time-consuming to review. In these cases, the Linux tail command is an efficient way to extract only the most relevant portions of a log.
The tail command displays the end of a file, which is usually where the most recent activity is recorded. By default, it shows the last 10 lines:
tail mysqld.log
Use the required application name instead of
mysql.
You can customize the number of lines with the -n option, as follows.
tail -n 100 mysqld.log
This command fetches the last 100 lines, which is often enough to capture the error or performance event in question.
In case log is required for real-time monitoring, you can use tail -f option. It continuously streams new log entries as they are written.
tail -f mysqld.log
RPM application
When working with RPM-based systems (RHEL, CentOS, Rocky, etc.), logs related to package management and RPM operations are usually stored in a few well-known locations. For example, the logs/ files in RPM environment may be as follows.
- RPM / YUM / DNF log locations. General System Logs (often contain RPM activity) are usually stores in these locations:
/var/log/messages;/var/log/syslog(on some distros).- Hence, you may find entries about RPM transactions here.
tail -n 50 /var/log/messages | grep rpm
- YUM logs (older RHEL/CentOS 7 and below). Tracks package installs, updates, and removals done with
yumin/var/log/yum.log
tail -n 20 /var/log/yum.log
Example entry may be as follows.
May 10 14:32:14 Updated: openssl-1.0.2k-21.el7_9.x86_64
- DNF logs (RHEL 8+, Fedora, Rocky, Alma, etc.).
/var/log/dnf.logis a transaction log./var/log/dnf.rpm.logis for low-level RPM operations.
tail -n 20 /var/log/dnf.log
Example
2025-09-19T11:24:01Z INFO --- logging initialized ---2025-09-19T11:24:05Z INFO Upgraded: python3-3.9.18-1.el8.x86_64
Use case
If you have an issue after updating or installing a package, instead of sending the entire /var/log/messages, you can extract the last 100 lines of DNF logs as follows.
tail -n 100 /var/log/dnf.log > dnf_snippet.log
This way, you share only the relevant snippet, not gigabytes of system logs.
