RabbitMQ TLS directory in Kubernetes
This directory should contain required SSL-specific files for running the reverse proxy in https mode.
  • rabbitmq.crt is for server certificate content.
  • rabbitmq.key is for server private key content.
  • rabbitmq.ca.crt is for Certificate Authority (CA) bundle content.
These files must go into the root level directory .rabbitmq and openiam-configmap/.rabbitmq.
Also, the following variables must be set:
In Terraform
rabbitmq.tls.enabled=true
In Helm:
--set openiam.rabbitmq.tls.enabled=true
