Configuring HTTPS in Kubernetes
This document is to help you to configure HTTPS in the Kubernetes environment.
SSL Certificate Directory
This directory should contain required SSL-specific files for running the reverse proxy in https mode.
openiam.crtfor the SSL Certificate fileopeniam.keyfor the SSL certificate key. This is required.openiam.sslchain.crt- this file will be used inSSLCertificateChainFilein Apache configurations.openiam.ssl.ca.crt- this file will be used inSSLCACertificateFilein Apache configurations.
Additionally, either openiam.crt or openiam.sslchain.crt is required.
In order for the reverse proxy to read and use these files, you need to set the following files and they also must go into openiam-configmap/.ssl.
In Terraform
rproxy.https.disabled=0
In Helm
--set openiam.rproxy.http=0
Updating the OpenIAM certificate in AKS
Pre-requisites
• Ensure the new certificate file, e.g. _6eddfb0689462086.crt is ready.
• This file should be used to replace existing openiam.crt.
• No need to run any Terraform apply.
• AKS cluster access is configured (kubectl is working).
• You have necessary permissions to edit ConfigMaps and delete pods.
To update the certificate, follow the steps below.
- Backup existing files and ConfigMap as follows.
cp /usr/local/openiam/kubernetes-docker-configuration/.ssl/openiam.crt /usr/local/openiam/kubernetes-docker-configuration/.ssl/openiam.crt.bakcp /usr/local/openiam/kubernetes-docker-configuration/openiam-configmap/.ssl/openiam.crt /usr/local/openiam/kubernetes-docker-configuration/openiam-configmap/.ssl/openiam.crt.bakkubectl get cm rproxy-ssl-certs -o yaml > rproxy-ssl-certs-backup.yaml
- Replace local certificate files by copying the new certificate over the existing one in both locations.
cp _6eddfb0689462086.crt /usr/local/openiam/kubernetes-docker-configuration/.ssl/openiam.crtcp _6eddfb0689462086.crt /usr/local/openiam/kubernetes-docker-configuration/openiam-configmap/.ssl/openiam.crt
- Edit Kubernetes ConfigMap and update the new certs as shown below.
kubectl get cm | grep proxkubectl edit cm rproxy-ssl-certs
- Restart rProxy Pod to apply changes.
kubectl get pods | grep rproxy # Find the rproxy pod namekubectl delete pod <rproxy-podname>
- Verify the update with the following command.
Log in to the web console and verify that the new certificate has been updated.
openssl x509 -in _6eddfb0689462086.crt -text -noout<
