This type of installation is suitable for both el8 RHEL / CentOS version.
Also, during the installation you will be prompted to install MariaDB RDBMS. This is suitable for Demo and POC installations. If you have already had the database server, you should answer N for the prompt.
- Download the following files to a server that has internet access.
curl https://download.openiam.com/release/enterprise/4.2.1.15/rpm/openiam-4.2.1.15.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpmcurl https://download.openiam.com/release/enterprise/4.2.1.15/dependencies/el8/openiamrepo.tar.gz --output openiamrepo.tar.gzcurl https://download.openiam.com/release/enterprise/4.2.1.15/binaries/frontend.tar.gz --output frontend.tar.gzcurl https://download.openiam.com/release/enterprise/4.2.1.15/binaries/backend.tar.gz --output backend.tar.gzcurl https://download.openiam.com/release/enterprise/infra/httpd-libs.tar.gz --output httpd-libs.tar.gz
curl https://download.openiam.com/release/enterprise/4.2.1.15/rpm/openiam-4.2.1.15.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpmcurl https://download.openiam.com/release/enterprise/4.2.1.15/dependencies/el9/openiamrepo.tar.gz --output openiamrepo.tar.gzcurl https://download.openiam.com/release/enterprise/4.2.1.15/binaries/backend.tar.gz --output backend.tar.gzcurl https://download.openiam.com/release/enterprise/4.2.1.15/binaries/frontend.tar.gz --output frontend.tar.gzcurl https://download.openiam.com/release/enterprise/infra/httpd-libs.tar.gz --output httpd-libs.tar.gz
Create folder
/usr/local/openiam- backend.tar.gz;
- frontend.tar.gz;
- openiamrepo.tar.gz;
- httpd-libs.tar.gz.
Install from the RPM using the following command.
sudo rpm -i openiam-4.2.X.noarch.x86_64.rpmYou will see output like the following.
openiam/openiam/OpenIAM-Base-Local.repoopeniam/connectors/openiam/connectors/shutdown.shopeniam/connectors/start.shopeniam/env.confopeniam/services/openiam/services/shutdown.shopeniam/services/start.shopeniam/source-adapters/openiam/source-adapters/shutdown.shopeniam/source-adapters/start.shopeniam/utils/openiam/utils/autodb.shopeniam/utils/autoinit.shopeniam/utils/cluster_healthcheck.shopeniam/utils/curator/openiam/utils/curator/init.shopeniam/utils/elasticsearch/openiam/utils/elasticsearch/default.policy.diffopeniam/utils/elasticsearch/elasticsearchopeniam/utils/elasticsearch/elasticsearch.serviceopeniam/utils/elasticsearch/init.shopeniam/utils/elasticsearch/jvm.optionsopeniam/utils/flyway/openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mssql.m4openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysq.m4openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysql.m4openiam/utils/flyway/V0.0.0.0.000__initialization.sql.mysql.rds.m4...openiam/janusgraph/javadocs/package-listopeniam/janusgraph/javadocs/index.htmlopeniam/janusgraph/javadocs/constant-values.htmlopeniam/janusgraph/javadocs/help-doc.htmlopeniam/janusgraph/javadocs/allclasses-frame.htmlopeniam/janusgraph/javadocs/allclasses-noframe.htmlopeniam/janusgraph/javadocs/stylesheet.cssopeniam/janusgraph/javadocs/overview-summary.html/var/tmp/rpm-tmp.ElioLH: line 9: openiam: Is a directoryNo, user openiam does not exist. creatinguseradd: warning: the home directory already exists.Not copying any file from skel directory into it.shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directoryshell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directoryshell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directoryThe server will be restarted in 1 min to apply ulimit settings ...Shutdown scheduled for Wed 2023-11-22 21:20:46 UTC, use 'shutdown -c' to cancel.At this point the VM will reboot to initialize variables that are needed for stack components such as Elasticsearch.
Execute the initialization step the openiam-cli. During this step the system will be installing and configuring the various components that make up OpenIAM. Please follow the instructions on the screen.
sudo openiam-cli initThe first question:
Does this box have Internet access? [y/n]. Please enterNYou will be asked about installing MariaDB as a default database.
7.1. If you answer 'Y' for MariaDB installation, installer will prepare all files and after will ask you some details:
- The installation process will continue. The Cassandra backend as a Graph storage will be installed. Please, be patient as this process can take 4-5 minutes. If you see the ugly exception below, ignore it. This is a byproduct of Cassandra taking some time to start (this will be addressed in an upcoming release).
error: No nodes present in the cluster. Has this node finished starting up?-- StackTrace --java.lang.RuntimeException: No nodes present in the cluster. Has this node finished starting up?at org.apache.cassandra.dht.Murmur3Partitioner.describeOwnership(Murmur3Partitioner.java:284)at org.apache.cassandra.service.StorageService.getOwnershipWithPort(StorageService.java:5166)at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)at java.lang.reflect.Method.invoke(Method.java:498)at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:72)at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)at java.lang.reflect.Method.invoke(Method.java:498)at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:276)at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:112)at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java:46)at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:237)at com.sun.jmx.mbeanserver.PerInterface.getAttribute(PerInterface.java:83)at com.sun.jmx.mbeanserver.MBeanSupport.getAttribute(MBeanSupport.java:206)at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getAttribute(DefaultMBeanServerInterceptor.java:647)at com.sun.jmx.mbeanserver.JmxMBeanServer.getAttribute(JmxMBeanServer.java:678)at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1445)at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:76)at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1309)at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1401)at javax.management.remote.rmi.RMIConnectionImpl.getAttribute(RMIConnectionImpl.java:639)at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)at java.lang.reflect.Method.invoke(Method.java:498)at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:357)at sun.rmi.transport.Transport$1.run(Transport.java:200)at sun.rmi.transport.Transport$1.run(Transport.java:197)at java.security.AccessController.doPrivileged(Native Method)at sun.rmi.transport.Transport.serviceCall(Transport.java:196)at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:573)at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:834)at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$0(TCPTransport.java:688)at java.security.AccessController.doPrivileged(Native Method)at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:687)at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)at java.lang.Thread.run(Thread.java:750)Waiting for cassandra
Set OpenIAM username for openiam schema, default: idmuser | This is DB username that will be used to manage the openiam OpenIAM schema. This is the primary schema in the solution data related to OpenIAM are stored. Username will be used by the OpenIAM application to communicate with database. The default value is idmuser. |
Set OpenIAM password for openiam schema, default: idmuser | This is the password that will be used for username which was provided in the previous step. The default value is: idmuser |
Set OpenIAM username for activiti schema. For MySQL it will be the same as for openiam, default: idmuser | This is DB username that will be used to manage the activiti schema. User will be used by OpenIAM application to communicate with the database. Default value is idmuser. |
Set OpenIAM password for activiti schema. For MySQL it will be the same as for openiam, default: idmuser | This is the password that for the user associated with the activiti schema. The default value is idmuser |
Memory cache
- End user web session.
- Database object cache.
Initialize database schema
Use default value if this is new installation. If you are doing an update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0 | If this installation is an upgrade from an existing deployment, then the current version is important as it will determine which scripts need to be applied to upgrade the schema to the current version. If this is a new deployment, you can leave this blank |
This is the name of the OpenIAM core database. If using MariaDB, this is most likely to be openiam, default: openiam | This question provides the option to choose the primary database schema. You should leave this blank and let it default to openiam. This value should only be changed if the scripts have been altered by the customer. |
Possible values: MySQL, Postgres, MSSQL, Oracle. Type of the database that you are going to use with OpenIAM. The RDBMS have to be already installed, default: MySQL | Select the type of database that you will be using as the OpenIAM product repository. You can leave this blank if you will be using either MariaDB or MySQL. If you are using either PostgreSQL, Oracle or Microsoft SQL server, enter one the following values based on your database type: postgres, oracle, mssql. |
| Do you want to initialize OpenIAM Schema and Users? Select this if you are not created schema and users in RDBMS yet. Super user (root) password will be required [y/n] | If Y then installer will create schemas in database and corresponded RDBMS users as well. For Oracle/MSSQL it will generate an SQL script that must be performed manually. |
Enter username for Super user (for MySQL this is root), default: root | The installer needs a super user account or equivalent which has the privileges to create new schema, users, tables, etc. |
Enter password for super user (sa or root, depend on the DB type), default: | Enter the password for account provided in the last step. |
This is the hostname of where the OpenIAM core database is., default: localhost | Enter the host or DNS name of the server where the primary OpenIAM database will be deployed. |
This is the hostname of where the OpenIAM Activiti database is., default: localhost | Enter the host or DNS name of the server where the workflow database will be deployed. |
This is the port of where the OpenIAM Activiti database is. If using MariaDB, this is most likely 3306, default: 3306 | Enter the port number used by the database server hosting the workflow database. |
- C:\Users\Asus>scp openiam-4.2.1.15.noarch.x86_64.rpm root@10...*:/usr/local/openiam/
- root@10...*'s password:
- openiam-4.2.1.15.noarch.x86_64.rpm 23% 133MB 1.4MB/s 05:12 ETA`
| Content Provider Name | You can think of a content provider as an “alias” which represents a domain. This is described in more detail in the OpenIAM documentation. For this setup, please enter a value such as: Default CP |
Type N and press Enter.
