Deployment architecture in RPM
The following sections describe common deployment architectures that are used along with a list of network ports that need to be opened.
| Configuration | Description |
| Single node | Single VM deployment where all the components are deployed on a single host. |
| Three node cluster | OpenIAM services and infrastructure are deployed across three (3) hosts for HA with a database that is distributed. |
