Installing OpenIAM with a remote Database
In case your remote database is MySQL, you need to prepare it beforehand by running the following:
dnf install mariadb-server
systemctl start mariadb
systemctl enable mariadb
mysql_secure_installation
At this point, you need to answer installation questions.
firewall-cmd --add-service=mysql --permanent
firewall-cmd --add-port=3306/tcp --permanent
firewall-cmd --reload
Login to mysql console as root as run:
grant all privileges on *.* to 'root'@'%' identified by '<MY_PASSWORD>' with grant option;
Verify connection form openiam box by:
mysql -h DB_IP -uroot -p
When the remote database is ready, it is time to install OpenIAM. To install product using a remote database, repeat the installation steps indicated in general installation process till step 4.
The system will ask you, whether you want to install dtabase locally:
Answer "No", installation process will proceed until "Critical section" is finished and the system asks you to connect to a remote database.
Generate OpenIAM encryption secrets
Database
User to Access ElasticSearch. If you don't change it on the ES server side, leave it as elastic, default: elastic
Password for elastic to access ElasticSearch, default: VanrIwkYvDMtjzsw56228KoULtioOdlu
OpenIAM username for schema 'openiam': idmuser
OpenIAM password for schema 'openiam': idmuser
OpenIAM username for schema 'activiti': activiti
OpenIAM password for schema 'activiti': activiti
OpenIAM password for RabbitMQ message broker: passwd00
OpenIAM password for Redis: passwd00
OpenIAM Username to access ElasticSearch: elastic
OpenIAM password for elastic user to access ElasticSearch: VanrIwkYvDMtjzsw56228KoULtioOdlu
Please validate your input above, if your are OK with that enter 'y'. To repeat an information collecting procedure enter 'n' :y
Answer "Yes" to proceed database installation.
Note is you're using Flyway to istall Oracle database, be sure to check username in databse validation script. By default, it is AIMUSER. Hence, username to be typed in on the previous step is to be AIMUSER. Note also, if you're not using Flyway to create database, but create it on you own, be sure for the username and password in database validation script and in database configuration in the step above to coincide.
Further, installation will proceed and at the end will ask you for database configuration.
Database configuration.
Use default value if this is new installation. If you are doing update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0
This is the name of the openiam core database. If using mariadb, this is most likely 'openiam', default: openiam
This is the name of the openiam Activiti database. If using mariadb, this is most likely 'activiti', default: activiti
Possible values: mysql, postgres, mssql, oracle. Type of the database that you are going to use with OpenIAM. The RDBMS have to be already installed, default: mysql
Do you want to initialize OpenIAM Schema and Users? Select this if you are not created schema and users in RDBMS yet. Super user (root) password will required [y/n]:y
Initialization.
Enter username for Super user (for mysql this is root), default: root
Enter password for super user (sa or root, depend on the db type), default:
passwd00
This is the hostname of where the openiam core database is., default: localhost
194.233.175.51
This is the port of where the openiam core database is. If using mariadb, this is most likely '3306', default: 3306
This is the hostname of where the openiam activiti database is., default: localhost
194.233.175.51
This is the port of where the openiam activiti database is. If using mariadb, this is most likely '3306', default: 3306
FLYWAY_BASELINE_VERSION=0.0.0.0
FLYWAY_OPENIAM_HOST=194.233.175.51
FLYWAY_OPENIAM_PORT=3306
FLYWAY_ACTIVITI_HOST=194.233.175.51
FLYWAY_ACTIVITI_PORT=3306
FLYWAY_DATABASE_TYPE=mysql
Database will be initialized=Y
Root (Db admin) user name=root
Root (Db admin) user password=passwd00
Answer "Yes" to proceed.
The expected output for installed database is given below.
Mysql. Try to initialize automatically
mysql: [Warning] Using a password on the command line interface can be insecure.
/usr/local/openiam/conf/schema/mysql/openiam/
Flyway Community Edition 6.5.4 by Redgate
Database: jdbc:mysql://194.233.175.51:3306/openiam (MySQL 5.5)
Creating Schema History table `openiam`.`flyway_schema_history` with baseline ...
WARNING: DB: Name 'flyway_schema_history_pk' ignored for PRIMARY key. (SQL State: 42000 - Error Code: 1280)
Successfully baselined schema with version: 2.3.0.0
Successfully validated 1077 migrations (execution time 00:00.330s)
Current version of schema `openiam`: 2.3.0.0
Migrating schema `openiam` to version 2.3.0.0.001 - mysql schema common
Migrating schema `openiam` to version 2.3.0.0.002 - mysql schema security
Migrating schema `openiam` to version 2.3.0.0.003 - mysql idm data
Migrating schema `openiam` to version 3.0.0.0.001 - alter table attribute map
Migrating schema `openiam` to version 3.0.0.0.002 - create resource many to many mapping
Migrating schema `openiam` to version 3.0.0.0.003 - create group many to many mapping
Migrating schema `openiam` to version 3.0.0.0.004 - migrate role id
Migrating schema `openiam` to version 3.0.0.0.005 - migrate resource role mappings
Migrating schema `openiam` to version 3.0.0.0.006 - create role many to many mapping
Migrating schema `openiam` to version 3.0.0.0.007 - create group and role name constraints
Migrating schema `openiam` to version 3.0.0.0.008 - add authorization data to resources
Migrating schema `openiam` to version 3.0.0.0.009 - migrate menus to resources
Migrating schema `openiam` to version 3.0.0.0.010 - fix resource name and type
Successfully applied 1076 migrations to schema `openiam` (execution time 00:27.744s)
Database: jdbc:mysql://194.233.175.51:3306/activiti (MySQL 5.5)
Creating Schema History table `activiti`.`flyway_schema_history` with baseline ...
Successfully validated 7 migrations (execution time 00:00.015s)
Current version of schema `activiti`: 2.3.0.0
Migrating schema `activiti` to version 4.0.0.0.106 - activiti.mysql.create.engine
Migrating schema `activiti` to version 4.0.0.0.107 - activiti.mysql.create.history
Migrating schema `activiti` to version 4.0.0.0.108 - activiti.mysql.create.identity
Migrating schema `activiti` to version 4.0.0.0.212 - activiti history
Migrating schema `activiti` to version 4.2.1.0.001 - OE-348
Migrating schema `activiti` to version 4.2.1.0.999 - version
WARNING: DB: Name 'OPENIAM_VERESION_PK' ignored for PRIMARY key. (SQL State: 42000 - Error Code: 1280)
Successfully applied 6 migrations to schema `activiti` (execution time 00:00.713s)
Installation done successfully.
