Installation with Internet access.
The RPM install for 4.2.1.x now supports both EL8 and EL7 versions of CentOS. During the installation you will be prompted to install MariaDB RDBMS. The use of MariaDB is acceptable for Demo / POC environments or small deployments. If you already have a database infrastructure that you would like to use, then you should answer 'N' at the prompt, as will be described below. The steps below describe how to install OpenIAM.
  1. Download the RPM installer as follows.
    curl https://download.openiam.com/release/enterprise/4.2.1.7/rpm/openiam-4.2.1.7.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpm
  2. After the download is complete, install OpenIAM from the RPM with the following command. This process will update initial ulimit settings, required for later in the installation process.
You should see the output similar to one given below.
openiam/
openiam/jdk/
openiam/jdk/lib/
openiam/jdk/lib/server/
openiam/jdk/lib/server/libjvm.so
openiam/jdk/lib/server/Xusage.txt
openiam/jdk/lib/server/libjsig.so
openiam/jdk/lib/libmlib_image.so
openiam/jdk/lib/libawt_xawt.so
openiam/jdk/lib/jspawnhelper
openiam/jdk/lib/psfont.properties.ja
openiam/jdk/lib/jli/
openiam/jdk/lib/jli/libjli.so
openiam/jdk/lib/libawt_headless.so
openiam/jdk/lib/librmi.so
openiam/jdk/lib/libfontmanager.so
openiam/jdk/lib/libawt.so
openiam/jdk/lib/libjimage.so
openiam/jdk/lib/libj2pkcs11.so
openiam/jdk/lib/libzip.so
openiam/jdk/lib/libjsound.so
openiam/jdk/lib/psfontj2d.properties
openiam/jdk/lib/security/
openiam/jdk/lib/security/default.policy
openiam/jdk/lib/security/public_suffix_list.dat
openiam/jdk/lib/security/blacklisted.certs
openiam/jdk/lib/security/cacerts
openiam/jdk/lib/libjdwp.so
Your VM will reboot to apply changes to ulimit. After it reboots , reconnect to your VM by executing the following command.
  1. Start the initialization process which will download files required for installation from OpenIAM server. Please follow the instructions on the screen.
Internet on box
Type 'y' and press 'Enter'.
System will download additional files, extract them locally, update your repository and install some base packages. You will see output similar to the snippet below.
Initialize openiam
Download file openiamrepo.tar.gz from OpenIAM website
Download file backend.tar.gz from OpenIAM website
Download file frontend.tar.gz from OpenIAM website
workflow.jar
synchronization.jar
reconciliation.jar
openiam-esb.jar
idm.jar
groovy-manager.jar
email-manager.jar
device-manager.jar
business-rule-manager.jar
auth-manager.jar
idp.war
openiam-ui-static.war
selfservice-ext.war
selfservice.war
webconsole.war
reportviewer.war
openiamrepo/
openiamrepo/copy-jdk-configs-3.7-4.el8.noarch.rpm
openiamrepo/graphite2-1.3.10-10.el8.x86_64.rpm
openiamrepo/httpd-tools-2.4.37-39.module_el8.4.0+778+c970deab.x86_64.rpm
openiamrepo/mod_http2-1.15.7-3.module_el8.4.0+778+c970deab.x86_64.rpm
openiamrepo/libXdamage-1.1.4-14.el8.x86_64.rpm
openiamrepo/libXinerama-1.1.4-1.el8.x86_64.rpm
openiamrepo/perl-Math-BigInt-1.9998.11-7.el8.noarch.rpm
openiamrepo/mariadb-10.3.28-1.module_el8.3.0+757+d382997d.x86_64.rpm
openiamrepo/libXau-1.0.9-3.el8.x86_64.rpm
openiamrepo/libXcursor-1.1.15-3.el8.x86_64.rpm
openiamrepo/erlang-24.0.3-1.el8.x86_64.rpm
openiamrepo/oniguruma-6.8.2-2.el8.x86_64.rpm
openiamrepo/mariadb-server-utils-10.3.28-1.module_el8.3.0+757+d382997d.x86_64.rpm
openiamrepo/nss-util-3.53.1-17.el8_3.x86_64.rpm
openiamrepo/apr-util-openssl-1.6.1-6.el8.x86_64.rpm
Install 4 Packages
Total download size: 685 k
Installed size: 1.6 M
Downloading Packages:
(1/4): telnet-0.17-76.el8.x86_64.rpm 474 kB/s | 72 kB 00:00
(2/4): oniguruma-6.8.2-2.el8.x86_64.rpm 1.0 MB/s | 187 kB 00:00
(3/4): j q-1.6-8.e18.x86_64.rpm 621 kB/s | 203 kB 00:00
(4/4): m4-l.4.18-7.el8.x86_64.rpm 1.0 MB/s | 223 kB 00:00
Total 1.8 MB/s | 685 kB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : oniguruma-6.8.2-2.el8.x86_64 1/4
Running scriptlet: oniguruma-6.8.2-2.el8.x86_64 1/4
Installing : jq-1.6-8.el8.x86_64 2/4
Installing : m4-1.4.18-7.el8.x86_64 3/4
Running scriptlet: m4-1.4.18-7.el8.x86_64 3/4
Installing : telnet-1:0.17-76.el8.x86_64 4/4
Running scriptlet: telnet-1:0.17-76.el8.x86_64 4/4
Verifying : jq-1.6-8.el8.x86_64 1/4
Verifying : oniguruma-6.8.2-2.el8.x86_64 2/4
Verifying : telnet-1:0.17-76.el8.x86_64 3/4
Verifying : m4-1.4.18-7.el8.x86_64 4/4
Installed:
j q-1.6-8.el8.x86_64 m4-l.4.18-7.el8.x86_64
oniguruma-6.8.2-2.el8.x86_64 telnet-1:0.17-76.el8.x86_64
Complete!
  1. You will be asked if you want to install MariaDB as the default database.
Please answer Y if you would like to use the local MariaDB RDBMS as a database server. MariaDB is a good choice for quick and simple installations such as demos, POCs or small size production deployments of less than 500 active users. To use another database, please enter N. This question enables the installation of MariaDB so that it can be used later in the installation process.
4.1. If you answered Y, MariaDB installer will prepare the files needed to install and configure MariaDB. Once this process is complete, you will be asked the questions below. Answer them and proceed to the next step.
  • Enter current password for root (enter for none): -> Press: Enter button since a password has yet to be defined.
  • Set root password? [Y/n] -> Press y button and after Enter
  • New password: -> Type password for the root user. You will need it later during the installation.
  • Re-enter new password: -> Type the password for the root user as on the previous
  • Remove anonymous users? [Y/n] -> Press y button and after press Enter.
  • Disallow root login remotely? [Y/n] -> Press y button and after press Enter.
  • Remove test database and access to it? [Y/n] -> Press y button and after press Enter.
  • Reload privilege tables now? [Y/n] -> Press y button and after press Enter.
The snippet below provides a view of what you can expect to see in this part of the installation. Note, that for suссessful installation it is required to set a default OpenIAM password for root user in MariaDB as passwd00. So, when the system asks you to set a new password, type 'passwd00'.
NOTE: RUNNING ALL PARTS OF THIS SCRIPT IS RECOMMENDED
FOR ALL MariaDB SERVERS IN PRODUCTION USE! PLEASE READ EACH STEP CAREFULLY!
In order to log into MariaDB to secure it, we'll need the current password
for the root user. If you've just installed MariaDB, and you haven't set
the root password yet, the password will be blank, so you should just press enter here.
OK, successfully used password, moving on...
Setting the root password ensures that nobody can log into
the MariaDB root user without the proper authorisation.
Set root password? [Y/n] y
New password:
Password updated successfully!
Reloading privilege tables..
... Success!
By default, a MariaDB installation has an anonymous user,
allowing anyone to log into MariaDB without having to have
a user account created for them. This is intended only for testing,
and to make the installation go a bit smoother. You should
remove them before moving into a production environment.
Remove anonymous users? [Y/n] y
... Success!
Normally, root should only be allowed to connect from 'localhost'.
This ensures that someone cannot guess at the root password from the network.
Disallow root login remotely? [Y/n] y
... Success!
By default, MariaDB comes with a database named 'test' that
anyone can access. This is also intended only for testing,
and should be removed before moving into a production environment.
Remove test database and access to it? [Y/n] y
- Dropping test database...
... Success!
- Removing privileges on test database...
... Success!
Reloading the privilege tables will ensure that all
changes made so far will take effect immediately.
Reload privilege tables now? [Y/n] y
... Success!
Cleaning up...
All done! If you've completed all of the above steps,
your MariaDB installation should now be secure.
Thanks for using MariaDB!
  1. After MariaDB has been installed, the installer will
  2. move forward to a variety of infrastructure services
  3. including Etcd, Vault, Redis, RabbitMQ and Cassandra,
  4. which is the storage for the graph database used in OpenIAM.
  5. This process will take 4-5 min. You will see output similar to the example below:
Wait vault service to wakeup
Vault already initialized....
Vault already unsealed...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 260 100 260 0 0 26000 0 --:--:-- --:--:-- --:--:-- 26000
Generate OpenIAM encryption secrets
  1. The installer will ask a number of questions during the initialization process. For most questions, a default value has been provided to simplify the effort for users new to OpenIAM. The section which requires input from the installer is marked with the following message in the console: =============== CRITICAL SECTION ===============
OpenIAM has two schemas which are created by default: openiam and activiti. The openiam schema is the primary schema used by the platform and it stores a variety of information ranging from policies to user profile information and more. activiti is used to store information about workflows and their execution. The first set of questions raised by the installer are related to the creation of database users for each schema. Each question and its intent are listed below.
Set OpenIAM username for schema openiam, default: idmuserThis is the DB user name that will be used to manage the openiam OpenIAM schema. This is the primary schema in the solution data related to OpenIAM are stored. Users will be used by the OpenIAM application to communicate with the database. The default value is idmuser.
Set OpenIAM password for schema openiam, default: idmuserThis is the password that will be used for the username which was provided in the previous step. The default value is: idmuser
Set OpenIAM username for schema activiti. For MySQL it will be the same as for openiam, default: idmuserThis is the DB user name that will be used to manage the activiti schema. Users will be used by OpenIAM application to communicate with the database. Default value is idmuser.
Set OpenIAM password for schema activiti. For MySQL it will be the same as for openiam, default: idmuserThis is the password for the user associated with the activiti schema. The default value is idmuser
Database
Set OpenIAM password for schema 'openiam' , default: idmuser : passwd00
Set OpenIAM password for schema 'activiti'., default: activiti: passwd00
OpenIAM uses RabbitMQ as the message broker. RabbitMQ is the primary transport service used within the OpenIAM application. Services are loosely coupled and they communicate with each other through the message broker. Cross service communication is encrypted.
Memory cache password
  • End user web session
  • Database object cache
Elasticsearch credentials
Elasticsearch search is used by OpenIAM to enable fast searching of frequently used data. As with the components above, access to Elasticsearch is secured through its own set of credentials. You are prompted for this information as shown below.
User to Access ElasticSearch. If you don't change it on the ES server side, leave it as elastic, default: elastic
OpenIAM password for elastic user to access ElasticSearch: KtmHIv4yEhb4w7VRxhveTIDTHAgPfNmY
The information requested above is critical for the installation process. Mistakes in these steps can disrupt the installation process. To minimize such issues, you will be asked to review the above answers. If you agree with the information, select Y. If you need to fix some information, select N and the installer will walk you through this process again.
Cassandra
After processing the above information, the installer will then install Cassandra. Cassandra is the storage engine for Janus Graph DB. You will see output similar to the example below during this step.
Waiting for cassandra
4
Datacenter: datacenter1
Status=Up/Down
|/ State=Normal/Leaving/Joining/Moving
-- Address Load Tokens Owns (effective) Host ID Rack
UN 127.0.0.1 73.49 KiB 256 100.0% 9af6453b-2428-4927-9e6a-bb0be15b3fa9 rack1
Cassandra alive
Cassandra is ready to use. Continue...
Use default value if this is new installation. If you are doing an update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0If this install is an upgrade from an existing deployment, then the current version is important as it will determine which scripts need to be applied to upgrade the schema to the current version. If this is a new deployment, you can leave this blank.
This is the name of the OpenIAM core database. If using MariaDB, this is most likely openiam, default: openiamThis question provides the option to choose the primary database schema. You should leave this blank and let it default to openiam. This value should only be changed if the scripts have been altered by the customer.
This is the name of the openiam Activiti database. If using MariaDB, this is most likely activiti, default: activitiThis question provides the option to choose the database schema used by the workflow engine. You should leave this blank and let it default to activiti. This value should only be changed if the scripts have been altered by the customer.
Possible values: MySQL, Postgres, MSSQL, Oracle. Type of the database that you are going to use with OpenIAM. The RDBMS have to be already installed, default:mysqlSelect the type of database that you will be using as the OpenIAM product repository. You can leave this blank if you will be using either MariaDB or MySQL. If you are using either PostgreSQL, Oracle or Microsoft SQL server, enter one the following values based on your database type: postgres, oracle, mssql
Do you want to initialize OpenIAM Schema and Users? Select this if you are not created schema and users in RDBMS yet. Super user (root) password will required [y/n]If 'Y' then the installer will create schemas in the database and correspond with RDBMS users as well. For Oracle/MSSQL it will generate an SQL script that must be performed manually
Enter username for Super user (for mysql this is root), default: rootThe installer needs a super user account or equivalent which has the privileges to create new schema, users, tables, etc.
Enter password for super user (sa or root, depend on the db type), default:Enter the password for account provided in the last step
Do you use AWS RDS Mariadb? If Yes, make sure the RDS DB instance has the parameter log_bin_trust_function_creators = 1 [y/n]:Select 'n' if AWS RDS MariaDB is not being used for this deployment.
This is the hostname of where the OpenIAM core database is., default: localhostEnter the host or DNS name of the server where the primary OpenIAM database will be deployed.
This is the port of where the OpenIAM core database is. If using MariaDB, this is most likely 3306, default: 3306Enter the port number used by the database server hosting the primary OpenIAM database
This is the hostname of where the activiti database is., default: localhostEnter the host or DNS name of the server where the workflow database will be deployed.
This is the port of where the activiti database is. If using MariaDB, this is most likely 3306, default: 3306Enter the port number used by the database server hosting the workflow database
FLYWAY_BASELINE_VERSION=0.0.0.0
FLYWAY_OPENIAM_HOST=localhost
FLYWAY_OPENIAM_PORT=3306
FLYWAY_ACTIVITI_HOST=localhost
FLYWAY_ACTIVITI_PORT=3306
FLYWAY_DATABASE_TYPE=mysql
Database will be initialized=Y
Root (Db admin) user name=root
Root (Db admin) user password=openiam
Please validate your input above, if you are OK with that enter 'y'. To repeat an information collecting procedure enter 'n' :y
If you need to correct any answer, please enter n.
Once you select y, the installer will generate the database schema. Internally, this step is handled by a component called Flyway. Flyway is a database schema management and versioning utility. It's used to generate the schema as well as upgrade from one version to another.
Install reverse proxy
After, the system may ask whether you want to update httpd software. httpd is an Apache web-server used to host web-sites and applications, as well as process and provide response to requests. Enter y for the question below and proceed with installation.
The OpenIAM RPM installer will continue with initialization and apply the SQL scripts which are required for successful startup. The OpenIAM services will automatically run the application stack after successful initialization and will show you the current stack status. Usually startup takes around 10-15 minutes. You can view the status of the system as it's coming up using the command line tools described below in OpenIAM components and Status.
Please, ignore the
HTTP request sent, awaiting response... 404 Not Found
2023-11-09 21:04:58 ERROR 404: Not Found.
Check the startup process
The containers may take 8 to 15 minutes (depending your environment) to startup completely. You can watch the start up process using the command below. Note, that the UI container will take some time and be among the last to start up as it has dependencies on other components being up first.
Monitor the startup process
Openiam Status report Thu May 12 19:05:50 UTC 2022
[OK] - openiam-esb - Service working. Application status: [ UP ]
[OK] - workflow - Service working. Application status: [ UP ]
[OK] - groovy-manager - Service working. Application status: [ UP ]
[OK] - idm - Service working. Application status: [ UP ]
[OK] - reconciliation - Service working. Application status: [ UP ]
[OK] - email-manager - Service working. Application status: [ UP ]
[OK] - auth-manager - Service working. Application status: [ UP ]
[OK] - business-rule-manager - Service working. Application status: [ UP ]
[OK] - synchronization - Service working. Application status: [ UP ]
[OK] - device-manager - Service working. Application status: [ UP ]
[ERROR] - sas-manager - Service is not running.
[OK] - openiam-ui - Service working. Application status: [ UP ]
Ignore the SAS-Manager error. This service is linked with an integration that is not currently supported. It will be removed in future versions of OpenIAM.
You should see output similar to the example below
HTTP/1.1 200
Date: Wed, 19 Jan 2022 23:04:10 GMT
Server: Apache/2.4.37 (centos) OpenSSL/1.1.1k
Content-Security-Policy: default-src 'self' blob: 'unsafe-inline' 'unsafe-eval'; script-src 'self' 'unsafe-inline' 'unsafe-eval' apis.google.com; style-src 'self' 'unsafe-inline' 'unsafe-eval' *; form-action 'self' 'unsafe-inline' 'unsafe-eval' *; img-src 'self' *; font-src 'self' *; report-uri /selfservice/csp/report; report-to csp-endpoint
X-Frame-Options: sameorigin
Cache-Control: no-cache
Pragma: no-cache
x-openiam-force-auth: false
Content-Language: en-US
Content-Length: 4833
Set-Cookie: SESSION=YzgxOGJkYzItNzIwYi00MGYwLTk4OTItM2JlMDY4ZWIwY2Ey; Path=/; HttpOnly; SameSite=Lax
Vary: Accept-Encoding
OpenIAM Login page .
Application serversThis is the location of the OpenIAM service layer which the UI and rProxy need to communicate with. In most cases, the default value will be correct since each of these components will be deployed on the same host. However, this configuration provides the flexibility to have the UI and service layer on separate hosts.
Post installation information
Check status
Check service logs
To check current logs of any service you can use the following command. You can get the services using the following command: openiam-cli log <service_name> .
Start and stop
You can start the application using the following command:
Troubleshooting
It is possible to receive a timeout error during the installation of Elasticsearch during initialization. This issue can be rectified by setting the SELinux mode to Permissive. Please refer to Red Hat's documentation for Changing SELinux states and modes.
