Deploying OpenIAM on Kubernetes without Terraform
This guide describes how to deploy OpenIAM to a private (not AWS, GKE) kubernetes cluster via helm, but without terraform. This type of deployment is not recommended due to the number of helm variables.
If you are deploying to AWS or GKE, please use terraform!
Next, follow this guide to enable helm RBAC in your cluster.
In addition, run the following command to ensure that configmaps are created correctly. You only need to do this once, or when the underlying files change
mkdir -p openiam-configmap/.ssl && mkdir -p openiam-configmap/.apache && cp -r .ssl/* openiam-configmap/.ssl/ && cp -r .apache/* openiam-configmap/.apache/
Deploying
We provide a working example of how to deploy OpenIAM via helm. Please see setup-no-tf.sh. This contains all of the required values for each helm chart that we deploy.
Migration guide
pre-4.2.1 to 4.2.1
We've updated our vault datastore in 4.2.1. To migrate, you will have to do the following:
- Deploy with the
openiam.vault.migrateterraform variable set totrue, when deployingopeniam-vaultandopeniam - Wait for all pods to come up
- Redeploy with the
vault.migrateterraform variable set tofalse, when deployingopeniam-vaultandopeniam - Wait for all pods to come up
