The URL `docs-4.2.1.3/installation/6-kubernetes-installation/1-modules/2-aws` does not exist. This page may have been moved, renamed, or deleted.
- [Azure AKS](https://docs.openiam.com/installation/kubernetes/azure-aks.md)
- [AWS](https://docs.openiam.com/installation/rpm/cloud/aws.md)
- [Azure AKS with Terraform](https://docs.openiam.com/installation/kubernetes/terraform-aks.md)
- [Amazon EKS](https://docs.openiam.com/installation/kubernetes/amazon-eks.md)
- [AWS connector](https://docs.openiam.com/connector-configuration/aws.md)
GET https://docs.openiam.com/installation/kubernetes/azure-aks.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/kubernetes/azure-aks.md`).
