Deployment architecture
The following sections describe common deployment architectures that are used a long with a list of network ports that need to opened.
| Configuration | Description |
| Single node | Single VM deployment where all the components are deployed on a single host. |
| Three node cluster | OpenIAM services and infrastructure are deployed across three (3) hosts for HA with a database that is distributed |
