GCE Kubernetes Guide
This document is aimed at helping the user to deploy OpenIAM in GCE.
Set up the environment
  1. Authenticate into Google:
gcloud auth login
gcloud auth application-default login
  1. Set the project, replace YOUR_PROJECT with your project ID:
    PROJECT=YOUR_PROJECT
    YOUR_PROJECT is the project ID, not the project name. See Google Cloud Documentation for more on locating the Project ID in the Google Cloud Control Panel
    gcloud config set project ${PROJECT}
  2. Configure the environment for Terraform:
    export GOOGLE_PROJECT=$(gcloud config get-value project)
  3. Re-run setup.sh in the root of the project
  4. Enable the Service Management API:
    gcloud services enable cloudbuild.googleapis.com
    gcloud services enable compute.googleapis.com
    gcloud services enable servicemanagement.googleapis.com
    gcloud services enable sql-component.googleapis.com
    gcloud services enable sqladmin.googleapis.com
    gcloud services enable redis.googleapis.com
  1. Set the region variable in terraform.tfvars to region that supports GCS
  2. Some of our services, when running in GCE, require authentication into google cloud. For this, we a Service Account File. There are two ways to do this. Specifically, BigTable requires this.
  • You can simply use your gcloud credential file, and run this:
mkdir -p .google
mkdir -p openiam-configmap/.google
cp ~/.config/gcloud/application_default_credentials.json .google/gcloud.creds.json
cp ~/.config/gcloud/application_default_credentials.json openiam-configmap/.google/gcloud.creds.json
  • Follow these steps. You will have to make sure that the result json file is in .google/gcloud.creds.json
  1. Set the GKE-specific variables in terraform.tfvars
Variable NameRequiredDefault ValueDescription
regionYThe region to be deployed. For example, us-west2
replica_countYThe total number of nodes to be created in the kubernetes cluster
database.root.userYThe root username to the database
database.root.passwordYThe root username to the database
redis.google.memoryYMemory of the Redis instance (in GB)
database.google.instance_classNGoogle Instance class for the database instance.
For Mysql, see https://cloud.google.com/sql/pricing#2nd-gen-pricing
For Postgres, see https://cloud.google.com/sql/pricing#pg-pricing
Note - for Postgres, using any of the provided tiers will NOT be enough, due to limitations to the number of concurrent connections
see - https://cloud.google.com/sql/docs/postgres/quotas
If you're using Postgres, you will have to create a custom tier, and then use that as the value of this string. See https://cloud.google.com/compute/docs/instances/creating-instance-with-custom-machine-type#create
kubernetes.gke.machine_typeYMachine Type of GKE Cluster. See https://cloud.google.com/compute/docs/machine-types. Minimum is n1-standard-4
elasticsearch.helm.esJavaOptsY-Xmx1536m -Xms1536mES Java Arguments
elasticsearch.helm.replicasY1Number of replicas
Destroying
Due to a bug with terraform's helm provider in GCE, destroying the objects in GKE must be performed in several automated and manual steps.
First, run these commands:
terraform state rm module.deployment.module.helm
terraform state rm module.deployment.module.openiam-app
terraform state rm module.deployment.module.kubernetes
terraform state rm module.deployment.module.elasticsearch
terraform state rm module.deployment.module.monitoring
terraform state rm module.deployment.module.kibana
Next, run the destroy command:
terraform destroy # enter 'yes' when asked to do so
Finally, you will have to delete terraform's state files:
rm -rf terraform.tfstate*
