Single VM Install
The instructions below are valid for all OpenIAM v4.2.1.3.x deployments on CentOS 8 Stream and Red Hat Enterprise Linux (RHEL) 8.5
This section describes how to install OpenIAM on either CentOS 8 Stream / RedHat Enterprise Linux (RHEL) 8.5+ using a RPM distribution.
OpenIAM provides a RPM distribution which includes all of the dependencies except for the database and system tools to simplify the installation process. The completeness of the RPM file also enables deployments in locked down environments where there is no network.
You may download CentOS or RHEL from the following locations:
| Operating System | URL |
| CentOS 8 stream | http://mirror.math.princeton.edu/pub/centos/8.2.2004/isos/x86_64/ |
| RHEL 8.5 | https://www.redhat.com/en/technologies/linux-platforms/enterprise-linux |
The installation instructions below require root level privileges on the host where OpenIAM will be deployed. The person or team installing OpenIAM must be familiar with the CentOS/RHEL operating system, databases and services.
Minimum System requirements
| Configuration | Non-Production | Production |
| Memory | 48 GB | 64 GB |
| CPU | 8 CPUs | 12 CPUs |
| Disk | 80 GBs | 200 GB |
Validate your environment
Login to your VM as root or a privileged user.
To check the CPUs on your VM use: lscpu
To the memory on your VM use: free -m
The result of each of these commands MUST align with the above minimum requirements. For sizing assistance for a production deployment, either open a support ticket or contact your OpenIAM point of contact.
Example of output form the above command:
[root@li1262-180 ~]# lscpuArchitecture: x86_64CPU op-mode(s): 32-bit, 64-bitByte Order: Little EndianCPU(s): 8On-line CPU(s) list: 0-7Thread(s) per core: 1Core(s) per socket: 1Socket(s): 8NUMA node(s): 1Vendor ID: AuthenticAMDBIOS Vendor ID: QEMUCPU family: 23Model: 1Model name: AMD EPYC 7601 32-Core ProcessorBIOS Model name: pc-q35-3.1Stepping: 2CPU MHz: 2199.994BogoMIPS: 4399.98Hypervisor vendor: KVMVirtualization type: fullL1d cache: 64KL1i cache: 64KL2 cache: 512KL3 cache: 16384KNUMA node0 CPU(s): 0-7Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm cmp_legacy cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw perfctr_core ssbd ibpb vmmcall fsgsbase tsc_adjust bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves virt_ssbd arat[root@li1262-180 ~]# free -mtotal used free shared buff/cache availableMem: 31959 221 31473 16 264 31341Swap: 511 0 511[root@li1262-180 ~]#
SSH into your VM
To ssh into your newly created VM, follow the steps below: a) First get the IP address of your VM. You can do this using:
ip addr
b) Next use a tool such Putty or the terminal window on Mac and SSH to this linux host:
Example: ssh root@172.16.101.128
Install required packages
Before installing OpenIAM, please execute the commands below to install the required packages. If you have already logged in as “root”, you do not need to prefix them with “sudo”. If you have used another account, then you need to use “sudo”
| Description | Command CentOS 8+ | Command CentOS 7+ |
| Install tar | dnf install tar | yum install tar |
tar utility. It is usually included in el7 CentOS, but not in el8.
You may also run the following supporting commands to prepare the system for installation.
Command to check VM Operating System:
cat /etc/os-release
NAME="CentOS Stream"VERSION="8"ID="centos"ID_LIKE="rhel fedora"VERSION_ID="8"PLATFORM_ID="platform:el8"PRETTY_NAME="CentOS Stream 8"ANSI_COLOR="0;31"CPE_NAME="cpe:/o:centos:centos:8"HOME_URL="https://centos.org/"BUG_REPORT_URL="https://bugzilla.redhat.com/"REDHAT_SUPPORT_PRODUCT="Red Hat Enterprise Linux 8"REDHAT_SUPPORT_PRODUCT_VERSION="CentOS Stream"
Command to get system disk space:
#df -H
Filesystem Size Used Avail Use% Mounted ondevtmpfs 17G 0 17G 0% /devtmpfs 17G 0 17G 0% /dev/shmtmpfs 17G 8.9M 17G 1% /runtmpfs 17G 0 17G 0% /sys/fs/cgroup/dev/mapper/cs-root 52G 2.4G 49G 5% //dev/mapper/cs-home 25G 209M 25G 1% /home/dev/sda1 1.1G 295M 769M 28% /boottmpfs 3.4G 0 3.4G 0% /run/user/0
vi editor commands:
to edit -- type ito escape -- hit escto save and quit -- type :wq
