RabbitMQ TLS Directory
This directory should contain required SSL-specific files for running the reverse proxy in https mode.
rabbitmq.crt
- Server certificate contentrabbitmq.key
- Server private key contentrabbitmq.ca.crt
- Certificate Authority (CA) bundle content
These files must go into the root level directory .rabbitmq
and openiam-configmap/.rabbitmq
Also, the following variables must be set:
In Terraform
rabbitmq.tls.enabled=true
In Helm:
--set openiam.rabbitmq.tls.enabled=true
