Deploying OpenIAM with Terraform
This guide describes how to deploy OpenIAM with Helm and Terraform.
Install Terraform. If it is not already installed (visit terraform.io for other distributions).
Modify terraform.tfvars. Set the value of the "app_name" variable IN terraform.tfvars to be the same as the APP_NAME variable in env.sh
Set common variables in terraform.tfvars
Below there is a description of common variables, not specific to any cloud provider.
| Variable Name | Required | Description |
| app_name | Y | This MUST be equal to the APP_NAME variable in env.sh |
| helm_version | Y | Your helm version. Should be equal to the output of `helm version -c --short |
| app_name | Y | A unique identifier of your application |
| replica_count_map | Y | This is a map that determines which app get how many replicas. None of the values should be greater than replica_count, or the total number of available nodes |
| database.flywayBaselineVersion | Y | Flyway baseline version. set this to another value if you're |
| database.flywayCommand | Y | Flyway command to run. repair or migrate |
| database.type | Y | This is the type of database that you are using. Can be one of 'MariaDB', 'Postgres', 'Oracle', or 'MSSQL' |
| database.hibernate | Y (when using Oracle or MSSQL) | required for Oracle and MSSQL. Ignored otherwise |
| N otherwise | For a complete list, see https://docs.jboss.org/hibernate/orm/3.5/javadocs/org/hibernate/dialect/package-summary.html | |
| Example values: | ||
| org.hibernate.dialect.Oracle10gDialect ( the most common value for Oracle) | ||
| org.hibernate.dialect.SQLServer2008Dialect (the most common value for MSSQL) | ||
| database.root.password | Y - in AWS | The root password to the database |
| Y - when using OpenIAM's Mariadb | ||
| or Postgres images | ||
| N - otherwise | ||
| database.openiam.user | Y | Username to the Openiam database |
| database.openiam.password | Y | Password to the Openiam database |
| database.openiam.database_name | Y | Openiam database name |
| database.openiam.schema_name | Y | Openiam schema name |
| database.activiti.user | Y | Username to the Activiti database |
| database.activiti.password | Y | Password to the Activiti database |
| database.activiti.database_name | Y | Activiti database name |
| database.activiti.schema_name | Y | Activiti schema name |
| redis.password | Y | Redis password. Can be blank |
| rabbitmq.user | Y | RabbitMQ Username |
| rabbitmq.password | Y | RabbitMQ Password |
| rabbitmq.cookie_name | Y | RabbitMQ Cookie Name |
| rabbitmq.memory.memoryHighWatermark | Y | RabbitMQ Memory High Watermark |
| rabbitmq.memory.request | Y | RabbitMQ Requested Pod Memory |
| rabbitmq.memory.limit | Y | RabbitMQ Limit Pod Memory |
| rabbitmq.serviceType | Y | Service Type. Set to LoadBalancer to expose externally, or set to ClusterIP to set internally. |
| rabbitmq.tls.enabled | Y | Is TLS Communication Enabled for RabbitMQ? If yes, set to true. Otherwise, set to false |
| rabbitmq.tls.failIfNoPeerCert | Y | When set to true, TLS RabbitMQ connection will be rejected if client fails to provide a certificate |
| rabbitmq.tls.sslOptionsVerify | Y | Should peer verification be enabled? Default is verify_peer |
| rabbitmq.jksKeyPassword | Y | Password used to generate JKS file, if RabbitMQ TLS Communication is enabled |
| logging.level.bash | Y | Logging level of bash scripts. TRACE and DEBUG are equivalent, and both force bash to run with the '-x' argument |
| logging.level.app | Y | for production use please change log level to warn or error. Debug will generate a lot of information. possible values ERROR, WARN, INFO, DEBUG, or TRACE |
| rproxy.https.disabled | N | rproxy by default uses https. you can set this to 1 to disable https |
| rproxy.https.protocol | N | SSL Protocols options. if not set, apache 2.4 defaults will be used. |
| For Example: disable everything except TLSv1.2 and allow only ciphers with high encryption: | ||
| protocol="-ALL -TLSv1 -TLSv1.1 +TLSv1.2" | ||
| cipherSuite="HIGH:!MEDIUM:!aNULL:!MD5:!RC4" | ||
| rproxy.https.cipherSuite | N | SSL Ciphersuite options. if not set, apache 2.4 defaults will be used. |
| rproxy.https.host | N | if https uses non-default(443) port, specify full https host name for redirects from http to https. |
| for example: | ||
| host=https://node1.openiam.com:8001 | ||
| rproxy.defaultUri | Y | If user hit for example: http://demo.openiamdemo.com/ redirect him to |
| http://demo.openiamdemo.com/selfservice/ by default, instead of showing error 404 (not found). | ||
| rproxy.disableConfigure | N | this is set to 1 by default. this allow to configure content provider on first access. |
| But after that, it is possible to set it to 0 to disable ability to configure content provider using the /webconsole/setup url | ||
| rproxy.verbose | N | rproxy debug options. set any value for enable or keep empty for disable debug logging |
| rproxy.debug.base | N | debug option. Enable base debugging |
| rproxy.debug.esb | N | debug option. Enable debugging on calls to the ESB |
| rproxy.debug.auth | N | debug option. Enable debugging on authentication calls |
| rproxy.apache.extra | N | File that is included in httpd.conf in the rproxy Docker container. Should be extraApache.conf or empty |
| rproxy.vhost.extra | N | File that is included in httpd.conf in VirtualHost section in the rproxy Docker container. Should be extraVHost.conf or empty |
| rproxy.log.error | N | By default /dev/stderr used for OPENIAM_RPROXY_ERROR_LOG and |
| rproxy.log.access | N | /dev/stdout for OPENIAM_RPROXY_ACCESS_LOG. You can change that here, |
| for example use /dev/stdout for both error log and access log | ||
| or set access log to /dev/null and log only errors. | ||
| if not set, defaults used. | ||
| openiam.rproxy.deflate | N | Apache mod_deflate compression ratio. Values from 0 to 9. By default is set to 6 |
| openiam.rproxy.csp | N | Content-Security-Policy headers enabled by default. To disable set to '0' |
| openiam.rproxy.cors | N | Cross-Origin Resource Sharing headers enabled by default. To disable set to '0' |
| autodeploy.openiam | N | if true, the openiam stack will autodeploy on each terraform run |
| autodeploy.rproxy | N | if true, the openiam reverse proxy stack will autodeploy on each terraform run |
| autodeploy.vault | N | if true, the openiam vault stack will autodeploy on each terraform run |
| vault.cert.country | N | Vault Certificate Country Code. Ignored if you are using a custom vault certificate, as specified in the parent file. |
| vault.cert.state | N | Vault Certificate Country State. Ignored if you are using a custom vault certificate, as specified in the parent file. |
| vault.cert.locality | N | Vault Certificate Locality. Ignored if you are using a custom vault certificate, as specified in the parent file. |
| vault.cert.organization | N | Vault Certificate Organiztion. Ignored if you are using a custom vault certificate, as specified in the parent file. |
| vault.cert.organizationunit | N | Vault Certificate Organiztion Unit. Ignored if you are using a custom vault certificate, as specified in the parent file. |
| vault.vaultKeyPassword | Y | Password used to generate the vault jks certificate. Use a strong password. |
| vault.secrets.javaKeystorePassword | Y | Java keystore password |
| vault.secrets.jks.password | Y | OpenIAM JKS Encryption Password. Use a strong password. |
| vault.secrets.jks.keyPassword | Y | OpenIAM JKS Key Password. Use a strong password. |
| vault.secrets.jks.cookieKeyPassword | Y | OpenIAM Cookie Key Password. Use a strong password. |
| vault.secrets.jks.commonKeyPassword | Y | OpenIAM Common Key Password. Use a strong password. |
| vault.replicas | Y | The number of vault and consul replicas |
| vault.consul.storage | Y | How much storage to provision to Consul PVC |
Set the Cloud Provider
Open the file 'main.tf' and change the following line:
if using Google Kubernetes Engine:
source = "./modules/core/gke"if using AWS:
source = "./modules/core/aws"if deploying in-house:
source = "./modules/core/helm"if uzing Azure:
source = "./modules/core/azure"
Set variables specific to your cloud provider
Each cloud provider has it's own specific set of required and optional variables
Follow the guide based on your cloud provider:
Deploying
To deploy, run the following commands from the root folder of this project. It may tak a while for all services to create and deploy
terraform initterraform planterraform apply # enter 'yes' when asked to do so
Note: our terraform scripts will change your ~/.kube/config file
Also note - if using AWS, you may have to run the above command twice.
Destroying
Each cloud environment has it's own peculiarities (i.e. bugs) when destroying infrastructure.
Destroy your infrastructure based on your cloud provider:
Managing State
Terraform stores state in local files
terraform.tfstate*
In addition, running against AWS and GKE modifies your ~/.kube/config file.
When switching environments, you MUST save these files off, so that you can return to previous environments.
Migration guide
pre-4.2.1 to 4.2.1
We've updated our vault datastore in 4.2.1. To migrate, do the following:
- Deploy with the
vault.migrateterraform variable set totrue - Wait for all pods to come up
- Redeploy with the
vault.migrateterraform variable set tofalse - Wait for all pods to come up
