Installing OpenIAM with a remote database in RPM environment
OpenIAm offers many installation options one of which being able to install the platform using different databases. This can be a default MariaDB, included into installation package or one of the remote databases, such as Oracle, Postgres and MSSQL. The default database installation is covered in the standard installation procedure, whereas installing OpenIAM with one of the remote databases is covered in the documents linked below. These cover the required prerequisites, configuration steps, and key considerations to ensure a smooth and reliable setup. By following this guide, you will be able to deploy OpenIAM with MariaDB, databases hosted on a separate server, enabling better scalability, security, and infrastructure flexibility.
