High availability (HA) deployment using RPM
Organizations have the option to deploy the OpenIAM platform in a high availability configuration to ensure maximum uptime. While configurations will be customized for each customer depending upon their specific IT infrastructure, the concepts and methods explained in this document will provide a foundation and reference to creating an HA strategy. The benefits of an HA deployment include:
  • Minimized downtime. By eliminating a single point of failure, organizations can achieve the five nines (99.999%) of uptime.
  • Scalability. Load balancers use algorithms to distribute the workload between multiple servers during periods of high traffic.
There are several different topologies that a customer can choose from when considering high availability architecture. The simplest and most common type of HA deployment is a three-node cluster that is horizontally scaled out. Load balancing is employed to ensure there is an optimal distribution of resource utilization across the nodes.
This document will cover the steps to create an HA configuration using an RPM deployment.
Example HA deployment architecture
Three-node cluster
As indicated above, there are several deployment options when considering an HA configuration. A common high availability configuration used in mid-sized customers is the three-node cluster. Three-node clusters are a popular choice for HA configurations due to the performance and scalability benefits. For example, in the event of a node failure in a two-node cluster, the burden would shift to only one server which could potentially spike resource utilization on that node and throttle performance. Alternatively, during a server failure in a three-node cluster the burden would be split between the two remaining nodes and thus the stress on each server is diminished comparatively.
In this type of deployment, all the OpenIAM services and infrastructure are replicated on each of the three Linux hosts that make up the cluster. The database is external to these servers and can have its own cluster.
If integration to Active Directory or another Microsoft application is required, then a Windows VM should be used to host the connector. In this example, we use the Active Directory PowerShell connector.
Note: This diagram is limited to integration with one application using common ports. The list of ports can change if integration with other applications is required.
Three-node cluster diagram
N-tier configuration
Some OpenIAM customers have large user populations that require greater capacity than is possible with a three-node cluster. Other customers have a need to expose the UI layer externally. These organizations thus opted for an n-tier HA configuration. One example of an n-tier deployment is shown below where there are 4 layers, and each layer has a three-node cluster.
  1. rProxy.
  2. OpenIAM services + UI.
  3. RabbitMQ.
  4. Infrastructure services such as Vault, Redis, etc.
User requests sent to the platform are distributed across the three UI nodes using an external load balancer. Within the platform, HAProxy is used to distribute the load across the components. HAProxy allows us to detect if an instance of a component is down and then distributing the load to the components that are available. When a service has been restored, HAProxy will resume sending traffic to all available components.
Hardware/VM requirements
For a three-cluster deployment, please ensure each VM meets the minimum requirements listed below.
Memory48 GB64 GB
CPU8 CPUs12 CPUs
Disk80 GB200 GB
OSCentOS 8/9 Stream / RHEL 8/9 / Rocky Linux 8/9CentOS 8/9 Stream / RHEL 8/9 / Rocky Linux 8/9
Software requirements
SpecificationRequirement
OSCentos8/Centos9/RHEL8/RHEL9/RockyLinux8/RockyLinux9
Supported browsersGoogle Chrome (v89.0.4389.114 and later), Microsoft Edge, Mozilla Firefox (v87 and later).
Note: Internet Explorer (IE) is not supported.
Installing OpenIAM in a three-node cluster
This section describes how to deploy OpenIAM in a three-node server cluster. Shell scripts are provided by OpenIAM to automate the installation for HA configurations.
Prior to installation
  1. Switch to the root account in a terminal window.
sudo -i
  1. Install Git on the node that will be used to configure and install OpenIAM on all three nodes. For the remainder of this section, we will refer to this node as the installation node.
dnf install git -y
  1. Generate SSH keys on the installation node. Select Enter for each question prompted by the terminal.
ssh-keygen
  1. Next, propagate the public key to all the nodes in the cluster. In the installation node terminal, enter the following commands and select Enter
cat ~/.ssh/id_rsa.pub >> ~/.ssh/authorized_keys
Copy the output from the above commands. SSH into the other two nodes and execute the following command.
echo "Value from the buffer" >> ~/.ssh/authorized_keys
For example:
echo "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDKcniMIHk8xwrR5lMQjCGS1fQSqJoOv1vStYORTW8ni7HS4diPtAEFbHMe/uYyIowMzwo6nBI7bzxyzwAPwSiuxQ7Qrv/FdNChS2sBT2pQVMHow81YA31XN6gutGQNVBMMCGe2FeVgPB8+GKvWIM9hxHCCVIfg/s/xNV7HFGJhd+mVIQZuN2OfMbfmJ1l11IhsKhgoF6OY6AzEOuesIY+sBnEIaRbUT12tBrqKIPwLgyeLH5fnp31sBmY637nCjc4pN4tQsiTdaxDuR4Q5Ynp2iF37NFuOBvCAOKfSDGX8gcN/uxqI24se5BpGSISizWLE+sFUstHgQFdbKsCtgMsv node1" >> ~/.ssh/authorized_keys
  1. Clone the openiam-cluster-rpm Git repository onto the installation node and switch to the latest version of OpenIAM using git checkout. This repository contains utilities to simplify the installation.
git clone git@bitbucket.org:openiam/openiam-cluster-rpm.git
cd openiam-cluster-rpm
git checkout RELEASE-4.2.2
Note: For this guide, version 4.2.2 is considered the latest release. The release should be replaced accordingly to a version going to be installed.
Note: you may need to upload your SSH key to Bitbucket. Instructions for doing so can be found on this page.
Firewall rules matrix
If your virtual machines are hardened with a security profile, you will need to allow the ports, following the matrix below.
SOURCEDESTINATIONPORTSERVICE
node1, node2, node2node1111, 2049, 20048, 32765, 32767NFS
node1, node2, node2node1, node2, node32379, 2380Consul
node1, node2, node2node1, node2, node38200, 8203VAULT
node1, node2, node2node1, node2, node39200, 9300OPENSEARCH
node1, node2, node2node1, node2, node34369, 15671, 15672, 25672RABBITMQ
node1, node2, node2node1, node2, node36379, 6390, 266379REDIS
node1, node2, node2node1, node2, node39142, 9160, 7000, 7001CASSANDRA
node1, node2, node2node1, node2, node38182, 9042JANUSGRAPH
node1, node2, node2node1, node2, node38080, 9080OPENIAM
Installation
  1. Update the file named infra.conf according to your infrastructure. Use VI or Nano to replace default values with the nodes' names and IP addresses.
nano ./infra.conf
  1. Next, execute the installation script. This step will require internet access.
./install.sh
Installation may take several minutes to complete.
  1. Initialization will begin. Answer questions when prompted.
Starting/Stopping OpenIAM
The OpenIAM cluster will start automatically following initialization. In the event you may need to start or stop OpenIAM at a single node or for the entire cluster, please refer to the following commands.
  • Starting OpenIAM components on a single node.
  • Stopping OpenIAM components on a single node.
  • Starting OpenIAM on the entire cluster.
cluster openiam-cli start
  • Stopping OpenIAM on the entire cluster.
cluster openiam-cli stop
Port communication matrix
HostPortsDescription
Following ports should be opened on each node in the cluster; Linux hosts nodes 1,2
OpenIAM cluster nodes443Primary port that will be used by end users after SSL has been enabled.
80Port that that will be used by end users before SSL is enabled.
8080Port that allows use of the OpenIAM using without going through the rProxy. Access to this port is helpful during development.
9080OpenIAM application port.
15672RabbitMQ management interface.
Following ports should be opened on each node in the cluster; Linux hosts nodes 1,2 to support inter cluster communication between stack components.
22SSH
25672RabbitMQ - Internode communication.
15671 (https)RabbitMQ
4369 (EMPD)RabbitMQ - Peer discovery service used RabbitMQ nodes and CLI tools.
9142 (https)Cassandra - Interconnect
9160, 7000, 7001Cassandra
8182, 9042JanusGraph
6379, 6390 (TCP)Redis
26379 (TCP)Redis Sentinel
9200, 9300 (http/https)ElasticSearch
2379, 2380 (TCP)ETCD cluster (Vault DB)
587SMTP Service connection.
111, 2049,20048,32767,32765 - (TCP/UDP)NFS
5672/5671/5673(TCP (AMQP))RabbitMQ port - Connectors that are deployed remotely will use this port to send messages back to RabbitMQ.
7199(TCP/UDP)Used for monitoring and management of Cassandra.
8500/TCPConsul server RPC.
8301/TCP, 8301/UDPLAN gossip communication between consul nodes.
8600/TCP, 8600/UDPConsul DNS Interface/Service discovery via DNS queries.
8300/TCPConsul Server RPC/internal communication/Leader election & Raft protocol.
8302/TCP, 8302/UDPCross-DC gossip and federation.
8503/TCPConsul HTTPS API.
8000(TCP/UDP)Management APIs, internal HTTP services, or utilities, inter-node port communication.
8081(http)IDP port
8082(http)WEBCONSOLE_PORT
8083(http)SELFSERVICE_PORT
8084(http)SELFSERVICE_EXT_PORT
8085(http)REPORTVIEWER_PORT
8086(http)UI_STATIC_PORT
8183(TCP (HTTP/HTTPS))HAPROXY_JANUS_PORT
9081(TCP (HTTP))HAPROXY_ESB_PORT
8087(TCP (HTTP/HTTPS))HAPROXY_UI_PORT
9201(TCP (HTTP/HTTPS))HAPROXY_ES_PORT
5002(TCP (HTTP/HTTPS))HAPROXY_RABBIT_UI_PORT
8200,8203 (HTTP/HTTPS)Vault
3000(TCP/HTTP/HTTPS)Grafana dashboard
9090(TCP/HTTP/HTTPS)Prometheus dashboard
9100(TCP/HTTP/HTTPS)Node exporter
Windows connector VM5672/5671Connector will send and receive messages back to RabbitMQ using this port.
5986WinRM ports used by the connector.
9389Used to access Active directory Web services.
Active Directory5986WinRM ports
9389Active Directory Web services.
636LDAPs for AD authentication.
Note that all of the above mentioned ports need to be opened in external firewall, source and destination will be each other for all the 3 Linux servers.
Load balancer configuration
After installing the OpenIAM server cluster, load balancing must be configured. Load balancers are available in hardware-based and software-based solutions.
The hardware load balancer leverages algorithms to distribute requests to the nodes of the cluster to maintain performance and redistributes traffic in the event of a node failure. A particularly common algorithm is round robin which simply forwards requests to the next available server in turn. In the three-node cluster example above, requests are directed to an external load balancer which then routes traffic to the appropriate OpenIAM node based on current server resource utilization.
Load balancing can also be configured to take place at the component level as opposed to the node level using a software-based solution like HAProxy which is configured on every node. For example, if the Redis or OpenSearch component in node 1 fails, the request can be forwarded by HAProxy to the same component in node 2.
An example topology displaying load balancing at the component level in a three-node cluster is shown below.
Three-node HAProxy diagram
