Single VM Install
OpenIAM provides an RPM distribution which includes all the dependencies and Maria DB to simplify the installation process. The completeness of the RPM file also enables deployments in locked down environments where there is no network. The following databases are not included in the distribution: Oracle, SQL Server, and PostgreSQL.
You may download CentOS or RHEL from the following locations.
| Operating System | URL |
| CentOS 9 | https://www.centos.org/download/ |
| RHEL | https://www.redhat.com/en/technologies/linux-platforms/enterprise-linux |
The installation instructions below require root level privileges on the host where OpenIAM will be deployed. The person or team installing OpenIAM must be familiar with the RHEL operating system, databases and services.
SSH into your VM
To ssh into your newly created VM, follow the steps below:
- First get the IP address of your VM. You can do this using:
ip addr
- Next use a tool such Putty or the terminal window on Mac and SSH to this Linux host.
ssh root@172.16.101.128
Minimum system requirements
| Configuration | Non-Production | Production (may increase based on sizing) |
| Memory | 48 GB | 64 GB |
| CPU | 8 CPUs | 12 CPUs |
| Disk | 80 GB | 200 GB |
Software requirements
| Specification | Requirement |
| OS | Centos8/Centos9/RHEL8/RHEL9/RockyLinux8/RockyLinux9 |
| Supported browsers | Google Chrome (v89.0.4389.114 and later), Microsoft Edge, Mozilla Firefox (v87 and later). Note: Internet Explorer (IE) is not supported. |
Infrastructure components, compatible with the current version of OpenIAM.
OPENSEARCH_VERSION="2.19.1"ELASTICSEARCH_VERSION="7.17.26"ERLANG_VERSION="26.2.5.15"RABBITMQ_VERSION="4.1.6"HTTPD_VERSION="2.4.63"TOMCAT_VERSION="9.0.111"VAULT_VERSION="1.18.1"MEDUSA_VERSION="0.7.2"CONSUL_VERSION="1.20.5"FLYWAY_VERSION="10.22.0"JANUSGRAPH_VERSION="1.1.0"MARIADB_VERSION="11.7.2"PROMETHEUS_VERSION="3.5.0"
Validate your environment
Login to your VM as root or a privileged user.
To check the CPUs on your VM use: lscpu
To the memory on your VM use: free -m
The result of each of these commands MUST align with the above minimum requirements. For sizing assistance for a production deployment, either open a support ticket or contact your OpenIAM point of contact.
Example of output from the above command is provided below.
[root@li1262-180 ~]# lscpuArchitecture: x86_64CPU op-mode(s): 32-bit, 64-bitAddress sizes: 48 bits physical, 48 bits virtualByte Order: Little EndianCPU(s): 16On-line CPU(s) list: 0-15Vendor ID: AuthenticAMDBIOS Vendor ID: QEMUModel name: AMD EPYC 7713 64-Core ProcessorBIOS Model name: pc-q35-7.2CPU family: 25Model: 1Thread(s) per core: 1Core(s) per socket: 16Socket(s): 1Stepping: 1BogoMIPS: 3999.99Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm cmp_legacy cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw perfctr_core ssbd ibrs ibpb stibp vmmcall fsgsbase tsc_adjust bmi1 avx2 smep bmi2 rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves clzero xsaveerptr wbnoinvd arat umip pku ospke vaes vpclmulqdq rdpid arch_capabilities[root@li1262-180 ~]# free -mtotal used free shared buff/cache availableMem: 64300 847 63754 16 314 63452Swap: 511 0 511[root@li1262-180 ~]#
You may also run the following supporting commands to prepare the system for installation.
Command to check VM Operating System is as follows.
cat /etc/os-release
Example of output form the above command.
VERSION="9.5 (Blue Onyx)"ID="rocky"ID_LIKE="rhel centos fedora"VERSION_ID="9.5"PLATFORM_ID="platform:el9"PRETTY_NAME="Rocky Linux 9.5 (Blue Onyx)"ANSI_COLOR="0;32"LOGO="fedora-logo-icon"CPE_NAME="cpe:/o:rocky:rocky:9::baseos"HOME_URL="https://rockylinux.org/"VENDOR_NAME="RESF"VENDOR_URL="https://resf.org/"BUG_REPORT_URL="https://bugs.rockylinux.org/"SUPPORT_END="2032-05-31"ROCKY_SUPPORT_PRODUCT="Rocky-Linux-9"ROCKY_SUPPORT_PRODUCT_VERSION="9.5"REDHAT_SUPPORT_PRODUCT="Rocky Linux"REDHAT_SUPPORT_PRODUCT_VERSION="9.5"
Command to get system disk space is as follows.
df -H
Filesystem Size Used Avail Use% Mounted ondevtmpfs 17G 0 17G 0% /devtmpfs 17G 0 17G 0% /dev/shmtmpfs 17G 8.9M 17G 1% /runtmpfs 17G 0 17G 0% /sys/fs/cgroup/dev/mapper/cs-root 52G 2.4G 49G 5% //dev/mapper/cs-home 25G 209M 25G 1% /home/dev/sda1 1.1G 295M 769M 28% /boottmpfs 3.4G 0 3.4G 0% /run/user/0
vi editor commands:
to edit -- type ito escape -- hit escto save and quit -- type :wq
Install required packages
Before installing OpenIAM, please execute the commands below to install the required packages. If you have already logged in as root, you do not need to prefix them with sudo. If you have used another account, then you need to use sudo.
| Description | Command CentOS 9+ |
| Install tar | dnf install tar |
Next steps
Directory structure
This section describes the location and structure of the OpenIAM installation. By default, the application is installed at: **/usr/local/openiam**. Within this directory, files are organized into the following subdirectories.
| Directory | Description |
conf/ | Contains configuration-related files and subdirectories:
connectors/ | Scripts to start and stop locally installed connectors. |
env.conf | Configuration file defining system-level settings. |
flyway/ | Contains Flyway-related configurations and database drivers for schema versioning. |
health/ | Stores the output of health check operations for OpenIAM services. |
janusgraph/ | Installation directory for JanusGraph. |
jdk/ | Java Development Kit (JDK) used by OpenIAM and other services. |
logs/ | Stores log files generated by OpenIAM services. |
openiamrepo/ | Contains RPM packages for OpenIAM components. |
services/ | JAR files for OpenIAM services, along with utilities to start and stop them. |
source-adapters/ | Scripts to start and stop source adapters. |
ui/ | Files and configurations related to the OpenIAM UI, including Tomcat, IdP, Self-Service, Web Console, and more. |
upload/ | Storage location for uploaded files. |
utils/ | Utilities for managing OpenIAM infrastructure components. |
vault/ | Contains policy files and certificates used by Vault. |
version | File containing the installed version of OpenIAM. |
