The URL `docs-4.2.1.5/installation/1-rpm-installation/6-upgrading` does not exist. This page may have been moved, renamed, or deleted.
- [Minor upgrade](https://docs.openiam.com/installation/rpm/rpm-upgrade/minor-upgrade.md)
- [Major upgrade](https://docs.openiam.com/installation/rpm/rpm-upgrade/major-upgrade.md)
- [Upgrading OpenIAM](https://docs.openiam.com/installation/rpm/rpm-upgrade.md)
- [Start and verify](https://docs.openiam.com/installation/rpm/rpm-ha/start-and-verify.md)
GET https://docs.openiam.com/installation/rpm/rpm-upgrade/minor-upgrade.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/rpm/rpm-upgrade/minor-upgrade.md`).
