The URL `docs-4.2.1.5/installation/6-kubernetes-installation/6-k8platforms` does not exist. This page may have been moved, renamed, or deleted.
- [Configure platform services](https://docs.openiam.com/administration-guide/platform.md)
- [Azure AKS with Terraform](https://docs.openiam.com/installation/kubernetes/terraform-aks.md)
- [Back up and restore](https://docs.openiam.com/installation/kubernetes/back-up-and-restore.md)
- [Amazon EKS with Terraform](https://docs.openiam.com/installation/kubernetes/terraform-eks.md)
