The URL `docs-4.2.1.5/installation/1-rpm-installation/10-ha-rpm` does not exist. This page may have been moved, renamed, or deleted.
- [Start and verify](https://docs.openiam.com/installation/rpm/rpm-ha/start-and-verify.md)
- [Three nodes](https://docs.openiam.com/installation/rpm/rpm-ha.md)
- [Configure the load balancer](https://docs.openiam.com/installation/rpm/rpm-ha/load-balancer.md)
- [Install](https://docs.openiam.com/installation/rpm/rpm-ha/install.md)
