The URL `docs-4.2.1.5/installation/1-rpm-installation/6-migrating-non-production-to-production-environment` does not exist. This page may have been moved, renamed, or deleted.
- [The JIT script contract and claim mapping](https://docs.openiam.com/administration-guide/federation/jit-provisioning/jit-provisioning-reference.md)
- [Review entitlements that live inside an application](https://docs.openiam.com/administration-guide/governance/certification/review-application-entitlements.md)
- [OAuth endpoints, grants, scopes and signing](https://docs.openiam.com/administration-guide/federation/oauth-and-oidc/oauth-and-oidc-reference.md)
- [Connector placement](https://docs.openiam.com/solution-architecture/integration/connector-placement.md)
- [Promote configuration between environments](https://docs.openiam.com/administration-guide/platform/import-export-and-promotion.md)
GET https://docs.openiam.com/administration-guide/federation/jit-provisioning/jit-provisioning-reference.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/administration-guide/federation/jit-provisioning/jit-provisioning-reference.md`).
