Installation with Internet access.
This type of installation is suitable for environments where the servers running the OpenIAM software will have internet access and can reach the OpenIAM website to download the software. You can validate this by running the command below.
The RPM install for 4.2.1.x now supports both EL8 and EL7 versions of CentOS. During the installation you will be prompted to install MariaDB RDBMS. The use of MariaDB is acceptable for Demo / POC environment or small deployments. If you already have a database infrastructure that you would like to use, then you should answer 'N' at the prompt. The steps below describe how to install OpenIAM.
Download Installer RPM with command
curl https://download.openiam.com/release/enterprise/4.2.1.5/rpm/openiam-4.2.1.5.noarch.x86_64.rpm --output openiam-4.2.X.noarch.x86_64.rpmInstall from the RPM with the following command:
You should see output similar to:
openiam/openiam/jdk/openiam/jdk/lib/openiam/jdk/lib/server/openiam/jdk/lib/server/libjvm.soopeniam/jdk/lib/server/Xusage.txtopeniam/jdk/lib/server/libjsig.soopeniam/jdk/lib/libmlib_image.soopeniam/jdk/lib/libawt_xawt.soopeniam/jdk/lib/jspawnhelperopeniam/jdk/lib/psfont.properties.jaopeniam/jdk/lib/jli/openiam/jdk/lib/jli/libjli.soopeniam/jdk/lib/libawt_headless.soopeniam/jdk/lib/librmi.soopeniam/jdk/lib/libfontmanager.soopeniam/jdk/lib/libawt.soopeniam/jdk/lib/libjimage.soopeniam/jdk/lib/libj2pkcs11.soopeniam/jdk/lib/libzip.soopeniam/jdk/lib/libjsound.soopeniam/jdk/lib/psfontj2d.propertiesopeniam/jdk/lib/security/openiam/jdk/lib/security/default.policyopeniam/jdk/lib/security/public_suffix_list.datopeniam/jdk/lib/security/blacklisted.certsopeniam/jdk/lib/security/cacertsopeniam/jdk/lib/libjdwp.so...
System will download additional files, extract them locally, update yum repository and install some base packages. You will see output similar to the snippet below.
Initialize openiamDownload file openiamrepo.tar.gz from OpenIAM websiteDownload file backend.tar.gz from OpenIAM websiteDownload file frontend.tar.gz from OpenIAM websiteworkflow.jarsynchronization.jarreconciliation.jaropeniam-esb.jaridm.jargroovy-manager.jaremail-manager.jardevice-manager.jarbusiness-rule-manager.jarauth-manager.jaridp.waropeniam-ui-static.warselfservice-ext.warselfservice.warwebconsole.warreportviewer.waropeniamrepo/openiamrepo/copy-jdk-configs-3.7-4.el8.noarch.rpmopeniamrepo/graphite2-1.3.10-10.el8.x86_64.rpmopeniamrepo/httpd-tools-2.4.37-39.module_el8.4.0+778+c970deab.x86_64.rpmopeniamrepo/mod_http2-1.15.7-3.module_el8.4.0+778+c970deab.x86_64.rpmopeniamrepo/libXdamage-1.1.4-14.el8.x86_64.rpmopeniamrepo/libXinerama-1.1.4-1.el8.x86_64.rpmopeniamrepo/perl-Math-BigInt-1.9998.11-7.el8.noarch.rpmopeniamrepo/mariadb-10.3.28-1.module_el8.3.0+757+d382997d.x86_64.rpmopeniamrepo/libXau-1.0.9-3.el8.x86_64.rpmopeniamrepo/libXcursor-1.1.15-3.el8.x86_64.rpmopeniamrepo/erlang-24.0.3-1.el8.x86_64.rpmopeniamrepo/oniguruma-6.8.2-2.el8.x86_64.rpmopeniamrepo/mariadb-server-utils-10.3.28-1.module_el8.3.0+757+d382997d.x86_64.rpmopeniamrepo/nss-util-3.53.1-17.el8_3.x86_64.rpmopeniamrepo/apr-util-openssl-1.6.1-6.el8.x86_64.rpm...Upgraded:cloud-init-21.1-7.el8_5.3.noarch kernel-tools-4.18.0-348.7.1.el8_5.x86_64kernel-tools-libs-4.18.0-348.7.1.el8_5.x86_64 kexec-tools-2.0.20-57.el8_5.1.x86_64libsss_autofs-2.5.2-2.el8_5.3.x86_64 libsss_certmap-2.5.2-2.el8_5.3.x86_64libsss_idmap-2.5.2-2.el8_5.3.x86_64 libsss_nss_idmap-2.5.2-2.el8_5.3.x86_64libsss_sudo-2.5.2-2.el8_5.3.x86_64 openssl-1:1.1.1k-5.el8_5.x86_64openssl-libs-1:1.1.1k-5.el8_5.x86_64 python3-perf-4.18.0-348.7.1.el8_5.x86_64qemu-guest-agent-15:4.2.0-59.module_el8.5.0+1063+c9b9feff.1.x86_64 selinux-policy-3.14.3-80.el8_5.2.noarchselinux-policy-targeted-3.14.3-80.el8_5.2.noarch sssd-client-2.5.2-2.el8_5.3.x86_64sssd-common-2.5.2-2.el8_5.3.x86_64 sssd-kcm-2.5.2-2.el8_5.3.x86_64sssd-nfs-idmap-2.5.2-2.el8_5.3.x86_64 systemd-239-51.el8_5.2.x86_64systemd-libs-239-51.el8_5.2.x86_64 systemd-pam-239-51.el8_5.2.x86_64systemd-udev-239-51.el8_5.2.x86_64Installed:kernel-4.18.0-348.7.1.el8_5.x86_64 kernel-core-4.18.0-348.7.1.el8_5.x86_64 kernel-modules-4.18.0-348.7.1.el8_5.x86_64Complete!
Please answer Y if you would like to use the local MariaDB RDBMS as a database server. MariaDB is a good choice for quick and simple installations such as demos, POCs or small size production deployments of less than 500 active users. To use another database, please enter N. This question enables the installation of MariaDB so that it can be used later in the installation process.
4.1. If you answered Y for MariaDB installer will prepare the files needed to install and configure MariaDB. Once this process is complete, you will be asked the questions below. Answer them and proceed to the next step.
Enter current password for root (enter for none):-> Press:Enterbutton since a password has yet to be defined.Set root password? [Y/n]-> Pressybutton and afterEnterNew password:-> Type password for the root user. You will need it later during the installation.Re-enter new password:-> Type the password for the root user as on the previousRemove anonymous users? [Y/n]-> Pressybutton and after pressEnter.Disallow root login remotely? [Y/n]-> Pressybutton and after pressEnter.Remove test database and access to it? [Y/n]-> Pressybutton and after pressEnter.Reload privilege tables now? [Y/n]-> Pressybutton and after pressEnter.
The snippet below provides a view of what you can expect to see in this part of the installation. Note, that for suссessful installation it is requires to default OpenIAM password for root user in MariaDB as passwd00. So, when the system asks you to set a new password, type 'passwd00'.
In order to log into MariaDB to secure it, we'll need the current password for the root user. If you've just installed MariaDB, and you haven't set the root password yet, the password will be blank, so you should just press enter here.Enter current password for root (enter for none):OK, successfully used password, moving on...Setting the root password ensures that nobody can log into the MariaDB root user without the proper authorisation.Set root password? [Y/n] yNew password:Re-enter new password:Password updated successfully!Reloading privilege tables..... Success!By default, a MariaDB installation has an anonymous user, allowing anyone to log into MariaDB without having to have a user account created for them. This is intended only for testing, and to make the installation go a bit smoother. You should remove them before moving into a production environment.Remove anonymous users? [Y/n] y... Success!Normally, root should only be allowed to connect from 'localhost'. This ensures that someone cannot guess at the root password from the network.Disallow root login remotely? [Y/n] y... Success!By default, MariaDB comes with a database named 'test' that anyone can access. This is also intended only for testing, and should be removed before moving into a production environment.Remove test database and access to it? [Y/n] y- Dropping test database...... Success!- Removing privileges on test database...... Success!Reloading the privilege tables will ensure that all changes made so far will take effect immediately.Reload privilege tables now? [Y/n] y... Success!Cleaning up...All done! If you've completed all of the above steps, your MariaDB installation should now be secure.Thanks for using MariaDB!
- After MariaDB has been installed, the installer will move forward to a variety infrastructure services including Etcd, Vault, Redis, RabbitMQ and Cassandra, which is the storage for the graph database used in OpenIAM. This process will take 4-5 min. You will see output similar to the example below:
2022-05-12T16:23:21.987Z [INFO] core: usage gauge collection is disabled2022-05-12T16:23:21.988Z [INFO] core: post-unseal setup complete2022-05-12T16:23:21.988Z [INFO] core: vault is unsealed2022-05-12T16:23:22.137Z [INFO] core: successful mount: namespace="\"\"" path=secret/ type=kv2022-05-12T16:23:22.430Z [INFO] core: enabled credential backend: path=cert/ type=certWait vault service to wakeupVault already initialized....Vault already unsealed...% Total % Received % Xferd Average Speed Time Time Time CurrentDload Upload Total Spent Left Speed100 260 100 260 0 0 12380 0 --:--:-- --:--:-- --:--:-- 12380Generate OpenIAM encryption secrets
OpenIAM has two schemas which are created by default: openiam and activiti. The openiam schema is the primary schema used by the platform and it stores a variety of information ranging from policies to user profile information and more. activiti is used by store information about workflows and their execution. The first set of questions raised by the installer are related to the creation of database user for each schema. Each question and it intent are listed below.
Set OpenIAM username for openiam schema, default: idmuser | This is DB user name that will be used to manage the openiam OpenIAM schema. This is the primary schema in the solution data related to OpenIAM are stored. User will be used by the OpenIAM application to communicate with database. The default value is idmuser. |
| Set OpenIAM password for 'openiam' schema, default: idmuser | This is the password that will be used for username which was provided in the previous step. The default value is: idmuser |
Set OpenIAM username for 'activiti' schema. For MySQL it will be the same as for openiam, default: idmuser | This is DB user name that will be used to manage the activiti schema. User will be used by OpenIAM application to communicate with the database. Default value is idmuser. |
Set OpenIAM password for activiti schema. For MySQL it will be the same as for openiam, default: idmuser | This is the password that for the user associated with the activiti schema. The default value is idmuser |
DatabaseSet OpenIAM username for schema 'openiam' , default: idmuserSet OpenIAM password for schema 'openiam' , default: idmuser : passwd00Set OpenIAM username for schema 'activiti'., default: activitiSet OpenIAM password for schema 'activiti'., default: activiti: passwd00
OpenIAM uses RabbitMQ as the message broker. RabbitMQ is the primary transport service used within the OpenIAM application. Services are loosely coupled and they communicate with each other through the message broker. Cross service communication is encrypted.
Memory cache password
- End user web session
- Database object cache
Elasticsearch credentials
Elasticsearch search is used by OpenIAM to enable fast searching of frequently used data. As with the components above, access to Elasticsearch is secured through its own set set of credentials. You be prompted for this information as shown below.
OpenIAM Username to access ElasticSearch: elasticOpenIAM password for elastic user to access ElasticSearch: ilm5LjYPAeFWbfLE40dthmEOunN4Cnlz
Cassandra
After processing the above information, the installer will then install Cassandra. Cassandra is the storage engine for Janus Graph DB. You will see output similar to example below during this step:
Starting cassandra (via systemctl): [ OK ]0nodetool: Failed to connect to '127.0.0.1:7199' - ConnectException: 'Connection refused (Connection refused)'.Waiting for cassandra1nodetool: Failed to connect to '127.0.0.1:7199' - ConnectException: 'Connection refused (Connection refused)'.Waiting for cassandra2error: No nodes present in the cluster. Has this node finished starting up?...Waiting for cassandra4Datacenter: datacenter1=======================Status=Up/Down|/ State=Normal/Leaving/Joining/Moving-- Address Load Tokens Owns (effective) Host ID RackUN 127.0.0.1 73.49 KiB 256 100.0% 9af6453b-2428-4927-9e6a-bb0be15b3fa9 rack1Cassandra aliveCassandra is ready to use. Continue...
| Use default value if this is new installation. If you are doing update, specify your current (before update) version here, like 4.1.11.0, default: 0.0.0.0 | If this install is an upgrade from an existing deployment, then the current version is important as it will determine which scripts need to be applied to upgrade the schema to the current version. If this is a new deployment, you can leave this blank. |
This is the name of the openiam Activiti database. If using MariaDB, this is most likely activiti, default: activiti | This question provides the option to choose the database schema used by the workflow engine. You should leave this blank and let it default to activiti. This value should only be changed if the scripts have been altered by the customer. |
| Do you want to initialize OpenIAM Schema and Users? Select this if you are not created schema and users in RDBMS yet. Super user (root) password will required [y/n] | If 'Y' then installer will create schemas in database and corresponded RDBMS users as well. For Oracle/MSSQL it will generate an SQL script that must be performed manually |
| Do you use AWS RDS Mariadb? If Yes, make sure the RDS DB instance has the parameter log_bin_trust_function_creators = 1 [y/n]: | Select 'n' if AWS RDS MariaDB is not being used for this deployment. |
| This is the hostname of where the OpenIAM core database is., default: localhost | Enter the host or DNS name of the server where the primary OpenIAM database will be deployed. |
This is the port of where the OpenIAM core database is. If using MariaDB, this is most likely 3306, default: 3306 | Enter the port number used by the database server hosting the primary OpenIAM database |
| This is the hostname of where the activiti database is., default: localhost | Enter the host or DNS name of the server where the workflow database will be deployed. |
This is the port of where the activiti database is. If using MariaDB, this is most likely 3306, default: 3306 | Enter the port number used by the database server hosting the workflow database |
Once the questions have been answered, the installer will provide a summary of the questions and answers. Please review before proceeding. An example of this is shown below:
Please validate information below---------------------------------FLYWAY_BASELINE_VERSION=0.0.0.0FLYWAY_OPENIAM_DATABASE_NAME=openiamFLYWAY_ACTIVITI_DATABASE_NAME=activitiFLYWAY_OPENIAM_HOST=localhostFLYWAY_OPENIAM_PORT=3306FLYWAY_ACTIVITI_HOST=localhostFLYWAY_ACTIVITI_PORT=3306FLYWAY_DATABASE_TYPE=mysqlDatabase will be initialized=YRoot (Db admin) user name=rootRoot (Db admin) user password=passwd00---------------------------------Please validate your input above, if your are OK with that enter 'y'. To repeat an information collecting procedure enter 'n' :y
If you need to correct an answer, please enter n.
Once you select y, the installer will generate the database schema. Internally, this step is handled by a component called Flyway. Flyway is a database schema management and versioning utility. It's used to generate the schema as well as upgrade from one version to another.
Install reverse proxy
After, the system may ask whether you want to update httpd software. httpd is an Apache web-server used to host web-sites and applications, as well as process and provide responce to requests. Enter y for question below and proceed with installation.
Do you want to update httpd to 2.4.54 ? [y/n]:
Check the startup process
The containers may take 8 to 15 minutes (depending your environment) to startup completely. You can watch the start up process using the command below. Note, that the UI container will take sometime and be among the last to start up as it has dependencies on other components being up first.
Monitor the startup process
Openiam Status report Thu May 12 19:05:50 UTC 2022[OK] - openiam-esb - Service working. Application status: [ UP ][OK] - workflow - Service working. Application status: [ UP ][OK] - groovy-manager - Service working. Application status: [ UP ][OK] - idm - Service working. Application status: [ UP ][OK] - reconciliation - Service working. Application status: [ UP ][OK] - email-manager - Service working. Application status: [ UP ][OK] - auth-manager - Service working. Application status: [ UP ][OK] - business-rule-manager - Service working. Application status: [ UP ][OK] - synchronization - Service working. Application status: [ UP ][OK] - device-manager - Service working. Application status: [ UP ][OK] - openiam-ui - Service working. Application status: [ UP ]
You should see output similar to the example below
HTTP/1.1 200Date: Wed, 19 Jan 2022 23:04:10 GMTServer: Apache/2.4.37 (centos) OpenSSL/1.1.1kReport-To: { "group": "csp-endpoint", "max_age": 10886400, "endpoints": [ { "url": "http://127.0.0.1/selfservice/csp/report" } ] }Content-Security-Policy: default-src 'self' blob: 'unsafe-inline' 'unsafe-eval'; script-src 'self' 'unsafe-inline' 'unsafe-eval' apis.google.com; style-src 'self' 'unsafe-inline' 'unsafe-eval' *; form-action 'self' 'unsafe-inline' 'unsafe-eval' *; img-src 'self' *; font-src 'self' *; report-uri /selfservice/csp/report; report-to csp-endpointAccess-Control-Allow-Origin: *X-Frame-Options: sameoriginX-Content-Type-Options: nosniffX-XSS-Protection: 1; mode=blockCache-Control: no-cachePragma: no-cacheExpires: Wed, 31 Dec 1969 23:59:59 GMTX-UA-Compatible: IE=EmulateIE10x-openiam-force-auth: falsex-openiam-login-uri: /idp/loginContent-Type: text/html;charset=UTF-8Content-Language: en-USContent-Length: 4833Set-Cookie: SESSION=YzgxOGJkYzItNzIwYi00MGYwLTk4OTItM2JlMDY4ZWIwY2Ey; Path=/; HttpOnly; SameSite=LaxVary: Accept-Encoding
The next screen will ask you to change the default password. As you enter your new password, you will see the password policy on the side. You password must align with this policy. You will be able to change both the password and the policy later.
The next step is to define a content provider using the screen shown below. A Content provider is an alias which represents a domain. Associated with the content provider can be UI themes, authentication policies, etc. The table below describes the fields on this screen.
| Content Provider Name | You can think of a content provider an “alias” which represents a domain. This is described in more detail in the OpenIAM documentation. For this setup, please enter a value such as : Default CP |
| Application supports SSL? | This configuration determines if the OpenIAM application will be accessed over HTTP or HTTPS. Unless, you have already configured the certificate, select Support on HTTP. You will be able to update this configuration later. |
After setting the content provider, you will be taken to the challenge questions page. These questions will be used to reset your admin account incase you have locked yourself out. Please make a note of your answers.
After completing the above steps, you will be taken the admin console landing page shown below. Allow the system about 5 min to refresh the internal cache and then you can proceed to configure your solution.
Post installation information
Check status
Check service logs
To check current logs of any service you can use the following command. You can get the services using the following command: openiam-cli log <service_name> .
Start and stop
You can start the application using the following command:
Troubleshooting
It is possible to receive a timeout error during the installation of Elasticsearch during initialization. This issue can be rectified by setting the SELinux mode to Permissive. Please refer to Red Hat's documentation for Changing SELinux states and modes.
