The URL `docs-4.2.1.5/installation/1-rpm-installation/6-upgrading/1-databasemigration` does not exist. This page may have been moved, renamed, or deleted.
- [Integration patterns for external systems](https://docs.openiam.com/administration-guide/operations/enterprise-integrations.md)
- [Install on a separate partition](https://docs.openiam.com/installation/rpm/rpm-single-node/separate-partition.md)
- [Integration: reaching the estate](https://docs.openiam.com/solution-architecture/integration.md)
- [Planning a wave migration](https://docs.openiam.com/solution-architecture/coexistence/planning-a-wave-migration.md)
