The URL `docs-4.2.1.5/installation/1-rpm-installation/1-singlenode/2-rpm-no-internet` does not exist. This page may have been moved, renamed, or deleted.
- [Back up and restore](https://docs.openiam.com/installation/rpm/rpm-single-node/back-up-and-restore.md)
- [Configure](https://docs.openiam.com/installation/rpm/rpm-single-node/configure.md)
- [First sign-in](https://docs.openiam.com/installation/rpm/rpm-single-node/first-sign-in.md)
- [Add a connector](https://docs.openiam.com/installation/rpm/rpm-single-node/add-a-connector.md)
- [Start and verify](https://docs.openiam.com/installation/rpm/rpm-single-node/start-and-verify.md)
GET https://docs.openiam.com/installation/rpm/rpm-single-node/back-up-and-restore.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/installation/rpm/rpm-single-node/back-up-and-restore.md`).
