Upgrading OpenIAM from versions 4.2.1.x to 2026.5.2 in RPM
The upgrading process to the newest OpenIAM version of 2026.5.2 is straightforward. The steps below detail the prerequisite steps for upgrading to OpenIAM 2026.5.2 for both single-node and HA-based RPM clusters.
Pre-upgrade prerequisites
- Make sure to backup the VM.
- Take a full snapshot of all three Linux VMs.
- Take a full snapshot/backup of the OpenIAM and Activiti databases from the external database instance.
- Observe the Firewall / Network requirements, as given in the table below.
| Host | Port | Description |
| OpenIAM cluster nodes | 8500/TCP, 8503/TCP, 8301/TCP, 8301/UDP, 8301/TCP, 8302/UDP, 8300/TCP, 8600/TCP, 8600/UDP | The following ports must be open between Consul agents (server/client) and other services. |
| 8081(http) | IDP port | |
| 8082(http) | WEBCONSOLE_PORT | |
| 8083(http) | SELFSERVICE_PORT | |
| 8084(http) | SELFSERVICE_EXT_PORT | |
| 8085(http) | REPORTVIEWER_PORT | |
| 8086(http) | UI_STATIC_PORT | |
| 8087(http) | Harproxy. |
Note: For all communication ports required for the HA-based cluster upgrade, please refer to the link link.
- Access requirements
- Admin-privileged credentials are required for all three Linux servers participating in the HA setup.
- Admin-privileged credentials are also required for the external database instance.
- Database preparation
- Create the Groovy initialization script on the database instance.
- This script will be shared by OpenIAM as per database type prior to the upgrade.
Note: Depending on the type of database, the SQL script will be provided from OpenIAM side in the upgrade ticket.
- Disk space requirement
- Approximately 50 GB of free disk space should be available.
- This must be verified based on the current utilization of the
/rootpartition.
- Please open a support case with OpenIAM before proceeding with the upgrade.
- Software Prerequisite: Please note that the upgrade is supported only on Enterprise Linux 8 (EL8) and Enterprise Linux 9 (EL9) platforms.
- Audit Log Recommendation: For environments where the audit log size is greater than 3 GB, it is recommended to export the audit log data prior to the upgrade. The upgrade script includes detailed procedures for both online and offline audit log export.
Upgrading scenarios
Internet-based upgrade
To upgrade OpenIAM from 4.2.1.x to 2026.5.2 with internet access, use the following command.
curl https://download.openiam.com/release/enterprise/infra/upgrade.sh --output /usr/src/upgrade.shFor HA based cluster upgrade:-curl https://download.openiam.com/release/enterprise/infra/ha_upgrade.sh --output ha_upgrade.sh
Non-internet-based upgrade
To upgrade OpenIAM from 4.2.1.x to 2026.5.2 without internet access follow the steps below.
- Download below files and keep it in
/usr/srcin Linux server and prepare the upgrade script as follows.
curl https://download.openiam.com/release/enterprise/infra/upgrade.sh --output /usr/src/upgrade.shchmod +x /usr/src/upgrade.shcp /usr/src/upgrade.sh /usr/local/openiam/utils/For HA based cluster upgrade:-curl https://download.openiam.com/release/enterprise/infra/ha_upgrade.sh --output ha_upgrade.shchmod +x ha_upgrade.shCopy the ha_upgrade.sh script to the openiam-cluster-rpm folderConfigure the "CONFIGURATION" section of this fileRun the script: ha_upgrade.sh
- Download required artifacts with the following commands.
curl https://download.openiam.com/release/enterprise/infra/elasticdump-offlines.tar.gz --output /usr/src/elasticdump-offlines.tar.gz
For EL9.
curl https://download.openiam.com/release/enterprise/2026.5.2/rpm/openiam-2026.5.2.noarch.x86_64.rpm --output /usr/src/openiam-2026.5.2.noarch.x86_64.rpmcurl https://download.openiam.com/release/enterprise/2026.5.2/dependencies/el9/openiamrepo.tar.gz --output /usr/src/openiamrepo.tar.gzcurl https://download.openiam.com/release/enterprise/2026.5.2/binaries/frontend.tar.gz --output /usr/src/frontend.tar.gzcurl https://download.openiam.com/release/enterprise/2026.5.2/binaries/backend.tar.gz --output /usr/src/backend.tar.gz
For EL8
curl https://download.openiam.com/release/enterprise/2026.5.2/rpm/openiam-2026.5.2.noarch.x86_64.rpm --output /usr/src/openiam-2026.5.2.noarch.x86_64.rpmcurl https://download.openiam.com/release/enterprise/2026.5.2/dependencies/el8/openiamrepo.tar.gz --output /usr/src/openiamrepo.tar.gzcurl https://download.openiam.com/release/enterprise/2026.5.2/binaries/frontend.tar.gz --output /usr/src/frontend.tar.gzcurl https://download.openiam.com/release/enterprise/2026.5.2/binaries/backend.tar.gz --output /usr/src/backend.tar.gz
Once all prerequisites are completed, start the upgrade using the command below:
