Upgrading OpenIAM in RPM
OpenIAM platform constantly improves and develops to provide more functionality and convenience to users. Hence, new versions are released, requiring an upgrade. Several upgrading options are currently available, as discussed below.
TypeDescription
Database migration from version 3.X to 4.XProvides steps for migrating a database from version 3.X to 4.X.
Upgrading infrastructure componentsGives guidelines on how to upgrade individual infrastructure components if required.
Upgrading from 4.2.1.5-4.2.1.8 versions to 4.2.1.10Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.10 version, considering the changes made.
Upgrading from 4.2.1.x versions to 4.2.1.11Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.11 version, considering the changes made.
Upgrading from 4.2.1.x versions to 4.2.1.12Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.12 version.
Upgrading from 4.2.1.x versions to 4.2.1.15Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.15 version.
Infrastructure upgrade in version 4.2.1.13Gives guidelines on how to upgrade individual infrastructure components in OpenIAM version 4.2.1.13.
Upgrading OpenIAM from versions 4.2.1.x to 2026.5.2Describes how to upgrade from 4.2.1.x versions to 2026.5.2 version.
Upgrading OpenIAM to 2026.2.1 versionThis document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory.
Upgrading OpenIAM to 2026.3.1 versionThis document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory.
Upgrading OpenIAM to 2026.3.2 versionThis document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory.
Upgrading OpenIAM to 2026.4.2 versionThis document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory.
Upgrading notes for v2026.5.2This page describes how to upgrade OpenIAM to v.2026.5.2 using RPM when it is installed under the root (/) directory and the configuration changes required.
Updating OpenIAM from 4.2.1.x versions to 2026.4.1 versionKnown issues related to upgrading from 4.2.1.x to 2026.4.1 version.
