Upgrading from versions 4.2.1.9-4.2.1.10 to version 4.2.1.11 in RPM
This document will guide the users on how to upgrade to version 4.2.1.11 from previous 4.2.1.9-4.2.1.10 versions.
Starting with OpenIAM version 4.2.1.4 upgrade.sh is a part of the RPM installation, so the upgrading process involves simple steps, as shown below.
  1. Set the parameter in the env.sh.
export UPGRADE_TO_VERSION=""
  1. Run the following command.
  1. Check all the services are up and running, by running the following command.
  1. Once all the services are up and running, login to OpenIAM and navigate to Administration > About OpenIAM.
The build version must be updated to 4.2.1.11.
Note: You must update connector if you use newer versions of the product. It is recommended to use the latest connector version.
All .NET/PS connectors versions as at 5.24.0.0 version are backward compatible, hence updating it will not disrupt operation of OpenIAM versions 4.2.0 and higher.
