Salesforce.com
The Salesforce.com connector enables provisioning/deprovisioning with Salesforce.com (SFDC). The section below describes how to deploy and configure the SFDC connector in your environment. The connector supports the REST interface for integration with SFDC. The connector supports the following functionality:
| Feature | Supported |
| CRUD operations for user | Y |
| Password synchronization | Y |
| User Lookup/Search | Y |
| Bulk user import/synchronization | Y |
Salesforce.com API version
This connector has been tested with SFDC REST API v39.0
Connector host
This connector requires a Linux host to operate. If you are deploying in a Kubernetes environment, the connectors will be deployed automatically. If you are using either the Docker or RPM file distribution, then follow the steps described in the installation section.
Service account privileges
The connector will need a service account to communicate with SFDC. The service account should have the following privileges:
| Privilege Name | Required |
| User with appropriate licenses | Y |
| Profile with API Enabled box | Y |
To turn on API Enabled, follow the steps below:
- Login to SFDC
- Go to Administration Setup -> Managed Users -> Create new Profile/"Edit" an existing user as shown in the image below
- Go to the Administrative Permissions section and select API Enabled box
Installing the connector
Based on the nature of your deployment, follow the proceedures below to deploy the connector.
Docker swarm
To start this connector in a Docker Swarm deployment, follow the steps described below:
- Uncomment the following line in
setup.shfile
setup.sh - #docker pull "openiamdocker/salesforce-connector-rabbitmq:debian-${OPENIAM_VERSION_NUMBER}-${BUILD_ENVIRONMENT}
startup.shfile
#docker stack deploy --compose-file connectors/salesforce/docker-compose.yaml --with-registry-auth salesforce-connector
For the changes to take effect you will need to stop your OpenIAM containers and then run:
./setup.sh./startup.sh
Kubernetes
In a Kubernetes deployment, this connector will be deployed automatically as part of the OpenIAM solution. No additional steps are required.
RPM Install
To run the connector via RPM, you need to download the jar file for this connector and run it using following command:
java -Dlogging.level.root=INFO -Dconfpath=/data/openiam/ -Dorg.openiam.connector.queue=SALESFORCE_Connector_1_Request -Dorg.openiam.connector.queueResponseName=SALESFORCE_Connector_1_Response -jar salesforce-connector-rabbitmq.jar>salesforce.out&
SALESFORCE_Connector_1 - default queue. If you create another connector config please update your configuration accordingly.
Use the command below to see the logs related to this connector:
tail -f salesforce.out
Register Connector in OpenIAM
The connector must be registered within OpenIAM for it to be operational. This process defines the message queue which will be used by the core OpenIAM services to communicate with the connector using the message below. To register the SFDC connector, login to the Webconsole and follow the steps below:
- Go to Provisioning -> Connector
- If an entry for the Salesforce.com connector does not exist then click on
Create new connectorfrom the side menu - Complete the fields as shown in the table below
| Connector configuration parameter | Description |
| Connector Name | This can be a descriptive name that will help you identify this connector such as: Salesforce.com |
| Metadata Grouping | Select Connector type |
| Metadata Type Name | Select Salesforce.com connector. This identifies the type of connector internally. |
| Connector Queue | Enter SALESFORCE_Connector_1. This is the name of the queue which the connector is using to receive messages. |
Security information needed to establish a connection
Generate a security token
Before we can establish a connection to SFDC using our connector, we must generate a security token which is used in the password field. You will need to do this on the SFDC side.
When you create an account you will get your security token. If you lose this token, then you can generate a new one using the steps below:
- For this you should login to your account and go to Personal Setup -> My Personal Information -> Reset My Security Token -> Reset Security Token
For additional information about generating a security token, please view: Salesforce.com security token
Client ID and Secret
If you plan to use the REST interface, you will also need to obtain the Client ID and Client Secret. You can obtain this from your tenant/account admin. This information can be obtained by doing the following:
- Login to SFDC
- Go to Create → Apps → Connected Apps -> click by name
- Open the needed app and you will see the
Consumer Key(Client ID) andConsumer Secret(Client Secret). These will be needed in the next step where we establish a connection from OpenIAM to SFDC.
Establishing a connection with your SFDC tenant
To establish a connection with your SFDC tenant, you must define a "Managed System" configuration by going to Provisioning -> Managed system in the Webconsole. As indicated earlier, the OpenIAM SFDC connector supports both REST and SOAP interfaces. Depending on the option you select, follow the steps below to define a managed system configuration.
OpenIAM Managed system configs REST:
| Managed System Field | Value |
| Host URL | https://[enter your tenant name].salesforce.com For example: https://mycorp.salesforce.com |
| API type | REST API |
| Login Id | Username |
| Password | Password + security token (like on word) |
| Grand Type | Enter password |
| Client ID | Client ID |
| Client Secret | Client Secret |
| API Version | Enter v39.0. This value is the REST API version |
If the connection is successful then in a few minutes you should see the connection healthcheck in green. If the healthcheck fails, it will be red and you will need to troubleshoot the connection further.
Example of a configured managed system:
Define the provisioning PolicyMap
The last step in the provisioning process is to define a policy map which determines how the connector will populate each attribute for the User object. To create a new policy map, follow the steps below and then use the table below to determine how each attribute should be defined.
- Go to
Policy Mapon the Managed system configuration used above - Click on the "Add" button and select
Provision userfrom the drop down
Additional information about the fields and their use can be found in the SFDC docs at: Salesforce API Documentation
| Field Name | Required | OOTB Groovy script | Value | |
| 1 | Alias | User alias. Need to create a custom field and get the value from there. Can’t be longer than 8 characters | ||
| 2 | DefaultGroupNotificationFrequency | Need to set default value in groovy or create custom field with type select. | ||
| 3 | DigestFrequency | Need to set default value in groovy or create custom field with type select. | ||
| 4 | This is set to the Primary email field in OpenIAM. Must be unique. | |||
| 5 | EmailEncodingKey | Need to set default value in groovy or create a custom field with type select. By default this is UTF-8 | ||
| 6 | FirstName | N | User's first name. Not required in salesforce, but required in OpenIAM | |
| 7 | IsActive | This attribute controls if the user is either active or disabled in SFDC. The default scripts use the Status in OpenIAM to determine this value. | ||
| 8 | LanguageLocaleKey | Need to set default value in groovy or create a custom field with type select. By default en_US. | ||
| 9 | LastName | User lastname | ||
| 10 | LocaleSidKey | Need to set default value in groovy or create a custom field with type select. By default en_US. | ||
| 11 | Password | User password. Not needed for provisioning -- only for reset password. If this field is inactive, password will be reset anyway, but the link with password will be sent to the user. If this field is active and we set a password, the password will be updated to the input. | ||
| 12 | ProfileId | Need to create a custom field. This field should contain ID of the profile where the user should be added. | ||
| 13 | TimeZoneSidKey | Need to set default value in groovy or create a custom field with type select. By default America/New_York. | ||
| 14 | Username | Principal. By default gets value from primary email. | ||
| 15 | UserPermissionsCallCenterAutoLogin | Need to set default value in groovy or create a custom field with type select. By default false. | ||
| 16 | UserPermissionsMarketingUser | This attribute is required in SFDC but is not in OpenIAM by default. Therefore, the value is in a groovy script. Alternatively, a custom field can defined. Default value is false. | ||
| 17 | UserPermissionsOfflineUser | This attribute is required in SFDC but is not in OpenIAM by default. Therefore, the value is in a groovy script. Alternatively, a custom field can defined. Default value is false. | ||
| 18 | UserPermissionsWirelessUser | This attribute is required in SFDC but is not in OpenIAM by default. Therefore, the value is in a groovy script. Alternatively, a custom field can defined. Default value is false. |
All of these fields except FirstName, LastName, Email, Password, IsActive should be created as custom fields for the user template. Most of them have a default value defined in groovy script.
Connector Troubleshooting Tips
Important:
When provisioning a newly created user, you cannot assign a password to the user as none of the API's allow you to manage the field to send emails to the new user with a password. The user must first be created without a password and then updated with the password. The password depends on the "Password" field in the Policy Map. After the password has been set, the user won't be able to log in for about five minutes. Please wait as this delay is from the Salesfoce.com side.
Errors:
After assigning a password to the user and then logging in to the Salesforce.com UI for the first time, the user will be asked to change their password. If you cancel this reset password, and then set a new password from the API you will see this exception below. However, the password will be set anyways.
[UnexpectedErrorFault [ApiFault exceptionCode='UNKNOWN_EXCEPTION' exceptionMessage='invalid repeated password' extendedErrorDetails='{[0]}']
