Upgrading OpenIAM in RPM
OpenIAM platform constantly improves and develops to provide more functionality and convenience to users. Hence, new versions are released, requiring an upgrade. Several upgrading options are currently available, as discussed below.
| Type | Description |
| Database migration from version 3.X to 4.X | Provides steps for migrating a database from version 3.X to 4.X. |
| Upgrading infrastructure components | Gives guidelines on how to upgrade individual infrastructure components if required. |
| Upgrading from 4.2.1.5-4.2.1.8 versions to 4.2.1.10 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.10 version, considering the changes made. |
| Upgrading from 4.2.1.x versions to 4.2.1.11 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.11 version, considering the changes made. |
| Upgrading from 4.2.1.x versions to 4.2.1.12 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.12 version. |
| Upgrading from 4.2.1.x versions to 4.2.1.15 | Describes how to upgrade from 4.2.1.x versions to the newer 4.2.1.15 version. |
| Infrastructure upgrade in version 4.2.1.13 | Gives guidelines on how to upgrade individual infrastructure components in OpenIAM version 4.2.1.13. |
| Upgrading OpenIAM from versions 4.2.1.x to 2026.6.1 | Describes how to upgrade from 4.2.1.x versions to 2026.6.1 version. |
| Upgrading OpenIAM to 2026.2.1 version | This document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory. |
| Upgrading OpenIAM to 2026.3.1 version | This document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory. |
| Upgrading OpenIAM to 2026.3.2 version | This document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory. |
| Upgrading OpenIAM to 2026.4.2 version | This document contains the step-by-step procedure to upgrade OpenIAM when it is installed under the root (/) directory. |
| Upgrading notes for v2026.5.2 | This page describes how to upgrade OpenIAM to v.2026.5.2 using RPM when it is installed under the root (/) directory and the configuration changes required. |
| Upgrading notes for v2026.6.1 | This page describes the configuration changes related to the new certification-manager microservice when upgrading OpenIAM to v.2026.6.1 using RPM. |
| Updating OpenIAM from 4.2.1.x versions to 2026.4.1 version | Known issues related to upgrading from 4.2.1.x to 2026.4.1 version. |
